Results 1 to 2 of 2
Thread: Dashboard light "D" not working
    Feb 2004
    01, Silver, 0603
    All of the other dash lights work, just not the D when it's in drive. Is this a bulb or fuse issue? I know the D is a different color then the rest, but nothing in the manual says anything about the fuse for the dash.
    If it's a bulb, how dramatic is it to change?
    It has it's own bulb.
    To see if it's even getting powered, you can try this:
    There is a blue 22-pin connector under the kick panel on the driver's side (there are many connectors, this is the only blue 22-pin one.). Look for a yellow/black wire. This is the wire that applies voltage to the "D" bulb. Make sure that it has a potential on it when the shift lever is in "D" (get an assistant).
    I only have a block diagram, not schematics, so I can't tell if this is a switch to ground or not.
    Here are some other indicator lamps on the same connector that you can check and compare it to:
    Park -red/black
    Reverse -red/blue
    Neutral -yellow/violet
  1. Replies: 35
  2. TOD "CHECK LIGHT"...intermittent at 60mph plus
    By JoFotoz in forum VX Troubleshooting...
    Last Post: 04/06/2009, 06:00 PM
  3. ABS Light ON - Left Rear Wheel Speed Sensor "Open"
    By lasturbo in forum VX Troubleshooting...
    Last Post: 02/17/2009, 08:00 AM
  4. Tail-light "Mulligan"
    Last Post: 04/01/2008, 07:31 PM
  5. Changing the factory "driving light" bulbs?
    By AndyC in forum VX Modifications...
    Last Post: 10/21/2002, 04:44 PM
