I went off the road this morning and had a bit of trouble. Need some advice on getting my baby started. i think the muffler may fulled with water.![]()
I will post pics as soon a i have time.
Not sure if this is a issue or not.
http://www.vehicross.info/forums/sho...&threadid=8850
From the pic you poted in your gallery I'd say the post Rowhard dirrected you too is probably your problem. Check your alternater. They have proven they don't like muddy water!
i havent really looked at the alternator to see if its even possible.. but has anyone fabbed up a plate or anythin to protect the alternator from splashing? i love goin mudding but didnt even realize that there was an issue with the alternators taking on water
would the muffler being filled with water create a starting problem?
All electricial is working but just doesn't turn over. believe or not she still running after all that, but the last time i started her she stalled as soon as i put her in gear. So what would be the next step????
she has been sitting on dry land for a few hours now. will the alternator dry out????
I going to try a syphon tube. does any know if there is a drain plug in the stock muffler?
