Results 1 to 4 of 4
Thread: amp install
    Aug 2003
    1999,Silver,Vehicross,0928
    amp install
    i know there were alot of threads regarding people installin amps under the driver seat, but i just got my new 4 channel, Lightning audio(i know is sh*tty but it was cheap) and its maybe 1/8-1/4" too high to clear the rear metal part of teh seat. any ideas on how to lower the amp alittle?
    Remove the foam under the carpet if you haven't already, cut a bit off of the metal that hangs down off the seat or use longer seat mount bolts with spacers. You'll likely have the same issue on the passenger side as well although I was able to put an amp and a flip out screen brain on that side on top of the TOD computer. Good luck.
    May 2004
    99 Astral Silver w/ SC
    or you could mount it behind the rear panels by the back door....lots of room behind the jack kit
    ----Trans Siberian Orchestra
  1. My CB install
    Last Post: 09/30/2010, 07:35 PM
  2. tie rod install
    By smorris65 in forum VX Talk...
    Last Post: 07/07/2005, 09:07 AM
  3. SC install not going to well....
    Last Post: 06/23/2004, 06:10 PM
  4. ps2 install
    Last Post: 09/27/2003, 07:36 AM
  5. Amp install help
    By DeafVX in forum VX Talk...
    Last Post: 08/26/2003, 05:56 PM
