Results 1 to 11 of 11
Thread: Windows XP loading question
    May 2004
    99 Astral Silver w/ SC
    I know this is way off topic, but since doing the occupations thread and seeing the diversity I figured I'd ask the question here before I go hunting down a computer help forum.
    I tend to format my comp occasionally just to clear it all up and I have found the easiest way of doing so without losing all my data is throw another hd in with a o.s. and copy the relavent stuff over. Soo, now I have two o.s's installed on two drives, no prob, xp recognizes this and asks which I want to boot up on. The problem comes when I am done copying files and remove the original drive xp still asks which o.s. I want to boot up on. I am sure this is a matter of just deleting a line or command or something, but I cannot find it anywhere. Any ideas?
    Also looking to disable the log in screen on bootup that asks which user I want to load even though I only have 1 user installed. I have heard this is related to xp patch 2, but havent figured out how to disable it yet either.
    Thanks
    Keith
    ----Trans Siberian Orchestra
    OK, to edit your startup options, do the following:
    RIGHT-CLICK on My Computer
    CLICK on Properties
    CLICK the Advanced Tab
    In the Startup and Recovery section, click SETTINGS
    This will open the Startup and Recovery dialog box
    In there, click on the EDIT button
    This will open your boot.ini file in Notepad
    You boot.ini file should look something like this:
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /noexecute=optin /fastdetect
    [boot loader]
    timeout=5
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
    Except yours probably has 2 lines under the [operating systems] section
    From here, you can just highlight and delete the line for the XP load on the hard drive you removed, leaving you with only 1 option
    Now, to disable the login screen at bootup, look at this link, it will save me some time
    http://www.petri.co.il/disable_the_w..._in_xp_pro.htm
    I hope that works for you.
    May 2002
    2000, Proton Yellow, VX, 0584
    With that all answered, you can also Dl the TWEAK UI interface for XP. It's put out by MS and there is a setting that allows you to automatically log in a default account. I also believe if you only have one account, don't use a password and that will bypass the screen too.
    Scott / moncha.com
    Hey Moncha, yes, if you are just using Administrator, or if you configured only one user are the begining, you should be able to bypass the login screen easily.
    Tweak UI is bad@55, I have used it for years.
    PS - As soon as I have a spare $20, I am going to become a site supporter. But I was wondering, is there a place I can see what all the ranks mean? (Like VXer and SuperVXer?) Just curious.
    Quote Originally Posted by Moncha
    May 2002
    The "Ranks" are just a silly way of see how many posts folks have made the more the posts the title changes.. I'd have to look myself, it's been so long since I set them up.. I'll post when I figure it out.
    No big deal, I was just curious
    May 2004
    Cool, thx for the quick info, btw I am thinking they will be in the order that they are listed on the screen, but how screwed am I if I delete the wrong one?
    The top line is:
    multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Micro soft Windows XP Home Edition" /fastdetect
    The next one is:
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
    On bootup I have to choose the bottom one, so I am assuming it would be the same here.....I guess I could always change the text that is displayed just to be on the safe side.
    May 2004
    Moncha, thats the way it use to work, or will work as long as you dont let xp update automatically. I only have 1 user, me being admin and it still pops up even without a password. Will check into the Tweak UI though..thx
    Yes, I believe that you should delete the line for the one that YOU DO NOT choose during startup. I do not think you will be hosed either way though, but then again, I never tried deleting the wrong one
    And just as an FYI, one thing to consider, if you reload a lot, is to buy a second hard drive and store all your data on it, and keep the main drive (usually C for the OS and for all your applications. This way, when you need to reload, you can safely format C: and install Windows again leaving your second drive with all your data alone. I like to reload about every 6 months myself, and what I did is just like what I said above, but after I initially installed a clean copy of the OS and all my applications, I used Ghost to create an "image" of my C: drive. So now when I want to reload, I can do it fast and not have to re-install/setup all my applications again. At most, I just need to do a Windows update and a mail restore (this is the only "data" I keep on C.
    I hope that made sense....
    Quote Originally Posted by Ruflyf
    The top line is:
    The next one is:
    May 2004
    No VX anymore. :(
    Just a PS:
    You may want to consider investing in Norton Ghost. It'll save you loads of time over reinstalling everything. Just do a clean install of all your software, patches, and set everything up the way you like it, then Ghost your whole system onto a backup drive and you're set. Just make sure to keep your data files separate from system files.
    Steve
    Yup, thats exactly what I do! Ghost rocks.
  1. Loading my VX for the first time
    By RodL in forum VX Talk...
    Last Post: 06/03/2013, 10:48 AM
  2. Windows...again
    Last Post: 01/02/2007, 03:49 PM
  3. windows
    By Matt in forum VX Troubleshooting...
    Last Post: 05/25/2005, 07:27 AM
  4. Windows
    By ramahama in forum VX Troubleshooting...
    Last Post: 05/04/2005, 12:09 PM
  5. Windows Windows Windows!
    By Garhead in forum VX Troubleshooting...
    Last Post: 09/22/2002, 10:02 PM
