Results 1 to 15 of 15
Thread: Stock Alarm problems
    99' Astral Silver
    Please help.
    I rewired my alarm antenna to the A pillar, it was fine for several days after I did this mod and I don't feel this has to do with my current problem..
    Currently the light on the dash that blinks when the alarm is armed is now stuck on. Meaning it is a solid red light regardless if the door is opened or not running or off. My alarm does not work nor does it make the beep noise when I click the remote.
    Any idea's? I did a search here and found no results. I did a search on VMAG and found one post with the exact problem I have but no one offered a resolution.
    I suspect I'll be able to figure it out but wanted ideas of what to start looking at?
    thanks for any assistance you folks can provide
    Live Free or DIE!
    Reset the alarm by pushing and holding the reset button on the brain (located under the dash to the far left of the brake pedal) and then hold down the button on the remote. More info on previous posts as to location.
    May 2002
    2000, Proton Yellow, VX, 0584
    If Tone's resolution doesn't work, disconnect your negative battery lead for a couple of minutes then re-attach.. It worked for mine... It just started flashing and honking then the light went solid all the while I was driving!
    Scott / moncha.com
    99' Astral Silver
    Thanks for the replies Tone and Scott,
    I tried Tones option first , took me a minute to find that green button but I DID find it
    I held in the green button for a minute or so ... let it go ... and then clicked the remote twice to no avail, so then, I held the green button in while I pressed the button on the remote for a mintute to no avail again.
    I decided to go get a bite to eat and a few drinks for a few then came home and disconnected the negative battery terminal, not knowing how long to leave it disconnected I simply hooked it back up after less than a minute ....alarm kicked on and scared the ***** out of me! Made several more attempts to connect the battery terminal but the horn again, kept beeping and scaring the ***** out of me (not expecting this after a few drinks at 11 pm ;eekg; ) finally ... I got the terminal hooked up. Tried the remote several times and it works like a champ now
    I guess the question I have now is....WHY DID I HAVE TO DO THIS?
    Was it ... the alarm / remote antenna re-location (that worked fine for the first 2-3 days after performing) and the alarm should have been reset after this procedure due to the signal difference?
    [OR
    was is something else, coincidentally, that had happened after the antenna re-location?
    Any ideas? as this will be good info for others down the road.
    May 2002
    Ooops! Forgot to mention that the alarm will go off as soon as you hook the neg back up... My bad, scared the doo doo out of me as well..
    Mine only happened once so far.. I kinda figure it's like have a Windows computer OS.. Once in a while you get a hiccup.
    '01 Proton #
    May I ask why you re-wired the alarm antenna? I have always thought the alarm system could have been a bit more complete/better. Any alarm mods out there that are useful?
    Happy Flying!
    Randy
    May 2002
    Here's the skinny
    Feb 2003
    Angry alarm antenna
    I have done this mod and it is an improvement, but I am still not impressed. Before the move I had to stand 10' or less before the alarm would arm or dearm. After the move, I can stand across the street and some times it will arm/de arm or not at all and I have to walk toward my V pushing the button untill it finally does work.
    Oct 2002
    Factory alarms... and I don't care which manufacturer it is... are all junk.
    I'm not going to go into details on why their junk. This is a public forum and everyone can get the info. Most of you know why already anyway.
    Best thing to do is to install a DEI or Compustar system and not deal with the factory system at all.
    Mar 2012
    sold
    anyone ever replace the stock siren with an aftermarket one? not the entire alarm i want to keep that stock just change the siren - mine has a very inconsistant beep that sounds different all the time...
    There are choices to be made...
    https://www.google.com/search?q=car+...Q&ved=0CDoQsxg
    Mar 2012
    sold
    thanks dub! i wonder if i could program the talking sirens to say whatever i want them to or make the noise of the hot lady walking by construction workers whistle? ...second thought it'll probably just get me in trouble
    Oct 2012
    1999, silver, vehicross, 0280
    Can someone tell me which remote works for the vx? I bought a remote HYQ1512R, is this the right remote?
    http://http://www.ebay.com/itm/150922998254?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
    Wrench
    Quote Originally Posted by ariastwin View Post
    Try this...from the "how to" section...
    If that doesn't work, you'll need to get one like this...
    http://www.ebay.com/itm/99-00-01-VEH...940f2e&vxp=mtr
    http://www.ebay.com/itm/REMOTE-CLICK...264d2f&vxp=mtr
    Oct 2012
    @Ldub- thanks for the info, I bought the wrong remote. Looks like seller has the correct item and should be able to exchange.
  1. Stock tires on wider than stock rims?
    By Y33TREKker in forum Wheels and Tires
    Last Post: 07/20/2013, 12:33 AM
  2. alarm question
    Last Post: 01/07/2009, 08:53 PM
  3. Stock alarm siren location
    By Ruflyf in forum VX Talk...
    Last Post: 11/22/2005, 05:13 PM
  4. VX Alarm
    Last Post: 05/20/2005, 11:57 PM
  5. OPC VX Alarm upgrade
    By azskyrider in forum VX Talk...
    Last Post: 03/08/2004, 07:35 AM
