I finally decided to replaced most of my exterior lights with LED's. I am very happy with the results, the LED's are either brighter or just look better than the stock filament lamps. The instant on/off of the brake and signal lights just makes the VX look fresh and modern, especially from the rear.
Many thanks to Scott for his informative review:
http://vehicross.info/modules.php?na...eview&id=4#top
Without it I would have never taken the plunge.
I was so intoxicated with the quick flashing that I decided to extend it and solder a wire in for the side marker conversion:
http://www.vehicross.info/modules.ph...ewarticle&id=5
But I found that there was a loss of resistance to trigger the flasher with these lights connected. So, I have yet to order parts, but I'm thinking this may work:
Let me know if I'm on the right track. The 6ohm resister would be the one I add to correct the circuit. Thanks.
