Results 1 to 15 of 39
Thread: Nervous, Worried, Help Please!
    Quote Originally Posted by Ruflyf
    First, check or have someone check the fluid lvl, making sure it looks right as well as being full. Then, I would try driving it with the "power" light opposite of how it was when the clunking happens to see if it still happens. Do you think the problem may be temperature related?
    Personally, I do not think the temp could have been the cause. The weather here has been mild, only around 65-70 degrees, and I was not driving long when this started happening....but what do I know! I will check the fluid levels this weekend when I do the rest of the stuff. And, just to let you know, I drove all the way home (13 miles) with no clunking and then later went and picked up my wife from work, and again, no problems...so go figure.
    Thx, Bart
    May 2004
    99 Astral Silver w/ SC
    Ok, but I was talking about the engine or transmission temp.
    Yeah, I'm not sure, no lights came on. Anyway I can tell?
    May 2004
    I would think if they light up during the pre-ignition start then the bulbs should be good.
    gone but not forgotten
    Could be the neutral safety/gear selector switch going bad, a common problem. If it does it again shift through the gears and see if it stops doing it. Switch is $120 to 150 depending on what kind of deal you can get at the dealer.
    albert
    ________
    volcano classic review
    Quote Originally Posted by skunkworks
    albert
    Is this the same as the "mode selector" everyone is talking about?
    1999, Ebony Black, VX ,1976
    The first thing to check is trans fluid level !!! It solved the problem for me. After the isuzu dealer did not add enough fluid back to the trans after changing the gaskets on the drain plugs. shawn
    1COOLVX
  1. Worried about leah
    By handeeman in forum VX Talk...
    Last Post: 08/17/2009, 07:16 AM
  2. Worried bout "crotchrocket"
    Last Post: 07/29/2009, 04:19 AM
