Results 1 to 12 of 12
Thread: BORBETS finally on! question, though..
    2001, kaiser silver, 1002 *SOLD 12/07*
    Exclamation BORBETS finally on! coming off, for now...
    well, after a lengthy time in the garage, the BORBETS purchased from Ron, are, finally, on the VX.
    However...
    Ron or Cyrk, are you there?
    I have shaved a bit of the front cladding at the front of the wheel wheel to accomodate some space for turning but the tires are rubbing on the the rear lower corner of the cladding along with the 1st screw (bottom one, which holds the cladding to the body?). I could probably shave the cladding a bit, but, what am I to do with the screw? I'm afraid to make a sharp rolling turn and tear off the bumper!
    any advise would be appreciated. GRACIAS!
    - jose
    2001 kaiser silver #1002
    '99 SC Ebony #1961
    Congrats, not sure as I have mine mounted with 255/55/18 Toyo's and no trimming was needed. Sorry and post some pics when you can!
    cyrk,
    thanks for the prompt response. i'll be sure to post pics, once all is set.
    take care!
    -jose
    2001 Ebony 0177
    Lift it up a bit!
    Arrow
    thanks, for the replies.
    i'll be performing minor surgery tomorrow. wish me luck.
    pics to follow (if i can get that right!)
    -jose
    after much consideration (and a chance to snap some pics), the BORB's will be coming off, at least temporarily. the tires were rubbing a little too much for my comfort. i'll start looking for a slightly narrower width tire. I know Cyrk had no issues with rubbing with his selection of tires, so I ,may pursue that route, as soon as the budget permits. I'm a bit bummed ( ), as they look sharp!! However, at least now, I'll feel alot better knowing I did not have to mutilate the VX simply for looks. thanks, all!
    -jose
    btw - as soon as I figure out how to post pics, i will.
    '99 SC Ebony #1961
    What size tires are you trying to use? 285?
    Well, you let me know if you want to unload them Borbets. I lost the bidding battle for them and my VX is already shaved down to accomodate them since I already have a larger tire and deep dish wheels.
    As Cyrk said, what size tire are you running? You can always go down to a lower profile and avoid many of the shaving issues, or, stick with a larger tire and shave, shave away. I shaved quite a bit just to fit mine. And yes, my VX did need anesthesia in order to take the sawzaw to her.
    hello. the tires are 265/60R18 110v (apparently, they're energized, as well).
    so, the stocks are back on, as of this evening. quite a difference!
    -jose
    May 2002
    2000, Proton Yellow, VX, 0584
    Quote Originally Posted by 2K1 1K2
    Try this for HELP
    Scott / moncha.com
    hello, sir. thank you!
    -jose
  1. Finally had to add a bit of oil
    By RodL in forum VX Talk...
    Last Post: 04/03/2013, 04:07 PM
  2. Replies: 15
    Last Post: 09/27/2012, 07:09 AM
  3. Well I finally did it!
    By Polie in forum Chit-Chat ...
    Last Post: 04/05/2012, 03:09 PM
  4. Finally!
    By H3_VX in forum VX Talk...
    Last Post: 01/12/2012, 01:46 PM
  5. Finally
    By twalker920 in forum VX Talk...
    Last Post: 10/08/2011, 06:11 AM
