Found your previous post. So you have an oil leak in the front. If the oil was coming from where you unbolted the adapter I would start by replacing the gasket,o-rings or whatever seals that up. Could be the adapter itself . It could be the seal on the crankshaft. Where on the front of the motor did you notice the oil ? If the oil pump was leaking it would not be leaking where you could see it. shawn
