Results 1 to 12 of 12
Thread: oil pump removal
    Apr 2006
    '99 Copper Orange Mica 1499
    I just got back from Missouri, where I purchased a Proton for the hunny. I bought it at a small dealership and since the inspector I paid to check the car out pre-purchase noted alot of seepage around the oil pan and tranny pan, I immediately took it over to Jack Miller Isuzu in Kansas City, MO.
    Andy, the Isuzu mechanic there, said that what tends to leak the most on these cars if it's not the oil pan is the seals. So you might want to look at the rear seal being your culprit. Not that I'm all that mechanically inclined but when he walked me around under the VX giving me a tour of what was right and what was wrong with my purchase, he mentioned that if there was still leakage after the oil cap gasket and the other leaks were fixed, that it's more than likely the seal.
    VX: What your Murano dreams it could be...
    1999, Ebony Black, VX ,1976
    What exactly is your problem ? Oil leak in the front of the motor ? The oil pump is in the oil pan . The pic is of the place were the oil filter adapter bolts to the front of the motor. shawn
    1COOLVX
    Found your previous post. So you have an oil leak in the front. If the oil was coming from where you unbolted the adapter I would start by replacing the gasket,o-rings or whatever seals that up. Could be the adapter itself . It could be the seal on the crankshaft. Where on the front of the motor did you notice the oil ? If the oil pump was leaking it would not be leaking where you could see it. shawn
    Apr 2006
    2007 Suzuki V-Strom 650
    I cleaned up around the pan and found the oil was coming out near the A/C unit not far above the oil pan. I decided to pull it apart and replace the front seal and all gaskets in that area. Now that it's apart, it doesn't appear to be the front seal but I'm gonna replace it anyways. It's either a faulty silicone job or one of those O-rings.
    I still need to know if the front seal housing (the shop manual labels it as the oil pump) requires the oil pan to be pulled to replace it. I'm probably gonna bite the bullet tomorrow and pull the front axle & oil pan to be sure before I bust any more ears off that thing. It won't budge.
    Apr 2006
    Got the front transaxle out today. Pulled the sump pan ... eww. There are brass _flakes_ in there. It looks like the engine was recently reassembled, so I'm hoping it's break-in debris. I got all the bolts out of the oil pan (what a pain), but the pan won't come off. I guess it's not the source of the leak
    Either way it's going to come off somehow ... if I break it, I guess I'll have to find one. It's getting tempting to just order a crate engine at this point, though. I still haven't found any obvious sources of the oil leak and have found plenty of other things that make me nervous.
    Would that new 3.5 people have been talking about bolt in directly? I can handle the wiring without too much trouble but don't want to have to fab too much in the way of exhaust and brackets.
    I'll update with some pics of the pan crud later when my wife relinquishes the laptop...
    Looks like I do have to pull the pan ... was searching for parts and found this:
    Apr 2006
    I got the rest of the oil pan off. Sometimes you just have to listen to dad ... I was trying to pry it off and generally avoid beating on it with a hammer. My dad said, "get a 2x4 and thump it until it comes free." Works like a charm and I didn't even damage the pan!
    Anyways, good news (or maybe bad). Judging by color differences, somebody rebuilt the engine recently since the crank, rods, and pistons look brand new while the rest of the engine is severely tarnished. I would have thought they would at least clean that up, but whatever.
    Here is the picture of the junk I found in the sump pan:
    My current guess is that's break-in junk. I hope. Second opinions?
    Here are some pictures of the bottom end of the engine. I now know why the pan has to come off the replace the oil pump. I'm not sure why the previous person working on it didn't do that step - I always replace oil pumps when replacing bearings. I don't think they replaced the seals around the pump either, which is probably where my oil leak came from.
    Behold:
    I hope this isn't a hackjob where the bearings will go again soon if they had spun in the block. Maybe they started knocking and the owner fixed it right away, but there's no evidence of any of the rods being new (all have what appear to be scars for being knocked off with a hammer).
  1. ABS Pump Module
    Last Post: 04/29/2016, 06:19 PM
  2. Water Pump replacement.
    Last Post: 06/06/2011, 01:09 PM
  3. air conditioning pump
    Last Post: 06/19/2007, 03:53 PM
  4. Gas prices at the PUMP!
    By azskyrider in forum VX Talk...
    Last Post: 05/13/2004, 11:49 AM
  5. Met an ex VX'er at the Pump
    By Jonnie in forum VX Talk...
    Last Post: 08/19/2003, 04:22 PM
