I assume (you know what that means! ) the kit you have is similar to mine. You want to bolt the solenoid inside the door several inches above the latch/lock mechanism.
You need to drill a hole through the bar that actuates the latch.
I don't remeber the size of the bit, but keep it small. Start the hole with a nailset or center-punch so the drill bit doesn't walk on you. put the cable through, loop it back towards the solenoid, and clamp the two ends together. You may have to adjust the tension of the cable a few times to get the desired result.
Hope this helps.
Brian
