MSHardeman, I will tackle the remote popper next! Like you have done, I will be wiring it to the factory (Rodeo) switch & wiring harness too. Wish me luck. I'll also be attempting to make it work off of my remote keyless entry keyfob... More relays!! Woohoo!
I don't have an answer for my problem yet (or yours), but I feel that I'm on the cusp of discovery! Check out the following link for an EXCELLENT primer on how to wire a simple relay. http://www.partsexpress.com/pdf/500-001.pdf I wish I could have found this earlier today while I was at work, "working" on this!![]()
I think that once I print this out tomorrow at work and take a little time to soak it all in, that I might just get this figured out.
Some questions that I still have are: WHY? - Are the Dashlights and Switch pins on the Foglight pic BOTH connected to the Green w/Red Stripe and WHY? - Are there two Ground pins? and WHY? - Does the On Indicator pin LOOSE power when the switch is depressed (on) and have power when the switch is off? <--My negative trigger theory.
In the meantime... If someone doesn't mind scribbling something down and posting how this system should be connected, I would be very gratefull. If not, then I guess I'll post it once I get it fingered out.
Once more, I have: 12V relay that will be wired to pass current to the lamps when the high beam circuit is energized. (12V to Relay Terminal 86 /WAIT! I think it all just gelled!!
Like Monchas picture shows... "On Indicator" pin goes TO RELAY. Yes... I read this before, but it didn't make any sense... until now! I guess I WANTED to have a 12V souce going to the relay to trigger it, but I DO. It is the 12V from the High-beam... the factory switch provides the Ground for the relay to operate! (For some reason I had it in my mind that the Foglight Switch was going to pass 12V to my relay... It all seems so simple now...)
Thank you to everyone who listened while I thought out loud! (Now I just hope it works when I try it out!) ...I still don't get why the Dashlights pin and the Switch pin are connected to the same wire. Does anyone have a wiring diagram of these two switches??
