Earl, the VX is laid up in the garage waiting to be put back together after having some rust spots on the roof repaired and the roof repainted. It has been a while (years) since it has been together and out of the road and I honestly don't remember how the rear door popper works now.
I know it does work with the OEM t-gate switch, but can't remember the sequence. I know one press of the unlock button on the key fob unlocks the driver and passenger doors. A second press triggers the rear popper.
Here's where I can't remember how things go. I know I can press the t-gate switch to trigger the rear popper, but I'm not sure if the other door(s) need to be open or closed. I know the little indicator light on the switch comes on when the rear door is open, but I think it also comes on when the other doors are open as well because of how I have things wired. I THINK if that little indicator light is on the switch won't work so it would stand to reason that if one of the doors is open I can't trigger the popper by pressing the switch.
I can't remember what I disconnected to get the interior out of the car to have the roof painted, but I'll head out there and see if things are hooked up. If they are I'll play around with the switch and the popper and report back on how/when it works.
