There are lots of single-DIN 5" LCD screens. The Pyle 5.6" unit that's all over ebay for $200 is one I'm considering.Originally posted by Tone
Can you explain how you are going to fit a 5” screen fit in a single din space?
I agree, it's definitely going to have to be tested before I'd advocate others planning on using that spot for a screen.The bottom slot is partially blocked by the shift lever so a popout screen is going to be difficult to see and use, especially when backing up.
Yeah, me, and just about everyone else around hereI agree about doing it right but YOU seem concerned about saving money.I know that personally I'd rather not spend $1,000-2,000 on this system, and if it can be done for $300, and still look and work well, that's a viable option. If I had unlimited funds, I'd put a MB SLK on the ML320 running gear (which I've seen on the net) but I don't have a mil to burn so I bought a VX
And you spent what?I already have a pop out 7” screen that is perfect and disappears when parked.
Well, the camera is 1.93" diameter I believe, and the pop-out plug is like 1.25 x 3", so we can either mount it inside and not use all of the IR LED's, or cut the half-moon a bit and sort of surface mount it. I guess we'll see when it gets here, it's not going to be the sort of thing you remove often (if ever) so a permanent mounting shouldn't be an issue.The camera you have power bought is quite large if it is the same as Ricks and only a few infrared LEDs will be able to “see” through the slim opening in the cover - Rick cut a hole so the whole camera can see outside.
What more would you like to know? I thought it was fairly complete.Randy, please fill out the rest of your profile so we’ll know more about you.
What if the Hokey Pokey really IS what it's all about?
Hahaha!
Let's open our arms to ALL new memebers to the board and embrace their new ideas.
What's this about a Johnson?
