ok my question is this, is the overall diamiter diffrent on the 18 inch wheels greater then the 16 inch wheels? or did the simply change the aspect ratio.
i don't own one of these yet but i will!
 New Member
						New Member
are you talking about the wheel+tire total?
IIRC the total diameter of the tire+wheels are the same for both the 16 and the 18 inch wheels. So when they changed the wheel size, they changed the aspect ratio of the tire needed.
2000 Black VX 105k
Koidiak - If you're considering a 1999 vs a later model, keep in mind that many 18" tires will cost you as much as $100 more per tire than the same model in a 16" size.
Originally Posted by VehiGAZ
Don't remind me!
Correct Maugan.
You can play with the tire/wheel calculators and see what works. You can find the OEM sizes in the Knowledge Base
Scott / moncha.com
