Decided to do a minor mod at work yesterday. I decided to swap the locations for the hazard light switch and the mirror defroster light switch. I have always had this thing about forgetting the defrosters on, making them wear much sooner than normal. And since the mirror defroster is in a place not easily seen, i forget to turn it off. (I know it probably has a timer or something). Plus it just seemed more at home next to the other defroster switch and I dont have that big red triangle staring at me anymore. Enough of my reasoning, and sorry for no during the process pics, but like I said I was at work and forgot to bring the camera.
It was overall very simple to do, although to this day I cant figure out why a hazard light switch has to have 8 wires.
Step 1
was taking the pars off, instr. panel cover, center console compartment. The gear shifter molding was just lifted up to run the wiring underneath.
Step 2
Figure out how long the wire needs to be, run 1 wire through, cut, then remove it. Then take 13 wires the same length and run them through from one end to the other (thats 8 for the hazard switch and 5 for the defroster switch.)
Option
You could trace the defroster wires back up to the dash and splice into them there, but I didnt really want to take anything else apart.
Step 3
Cut the plugs that go to the switches making sure you have enough room for soldering, etc. Now if you dont use 13 different colored wires like I didnt, you must have a volt meter to measure continuity. This gets a little tedious and is much easier with a helper. I found both ends of 1 wire at a time, and wired it to the corresponding switch. If your going to solder these, I suggest not stripping them all since they are switches, meaning some will be hot, or disconnect your battery. And of course either heat shrink or electrical tape all your connections as you go.
