Results 1 to 12 of 12
Thread: Check Engine Light
    Aug 2004
    1999 Astral Silver Vehicross 0491
    Check Engine Light
    Hey guys, need some help here.
    The "check engine" light came on when driving to work this morning. I read the portion in the manual about it, but I need to know if this is something that needs to be taken care of immediately or could it at least wait till the weekend? And this machine that it has be hooked up to, is this something that only an Isuzu dealer would have or will just about any higher class garage have one? Please advise....
    Any garage should have one. You could swing by an Autozone (or whatever name they use in your area) and they will come out and read the code for free. Then you will know what you need to fix.
    99' Astral Silver
    After that, go buy a scan guage from tone or other places on the net. Useful tool for the money if you ask me
    I hope todays problem is nothing serious for you.
    Live Free or DIE!
    Aug 2004
    Thanks you guys, I appreciate the help. There's an Auto Zone just a few blocks from work, will check it out after I leave.
    2001 Proton Yellow #1199
    check engine light
    Hey do a search of previous threads on this subject. It has been discuss multiple times with various causes, most very easy fixes. Acouple of these can be tried even before you make it to autozone (ie tighten the gas cap) Good luck!
    :_drool: It's all fun and games until it can't be fixed!
    Aug 2004
    Hey guys,
    Sorry to take so long to get back, I did go by Auto Zone and have my code read, the result was a defective EGR valve. The salesman 'suggested' that I buy a new valve, at $183, I declined telling him that my bro-in-law is a mechanic and that I would get with him about purchasing a new part.
    After reading thru several posts on the same topic, I'm curious, does a "defective valve" mean that I need to replace my current valve or can I simply try cleaning my existing valve?
    Any advice I would greatly appreciated.
    1999, sliver, vehicross 0782
    Unhappy
    i have my check engine light on too, that made me fail my smog check~ shtt~
    blue HID head light, custom license plate "GOVEHIX", Pro M mass air flow, black safari light bar from Tone, PIAA 194 fog light intalled, PIAA 550 fog light lamp installed, custom bull bar extention installed, Levoc ultra metal pedal set, Bioharzard sticker at the rear glass, Recaro red cellphone holder and razo steer cover.
    Occupation: Full Time VX Driver
    Apr 2006
    2007 Suzuki V-Strom 650
    Check the price for a 2000 S-10 pickup 4.3L and 1995 Camaro 3.8L -- it's the exact same EGR valve. I have the EGR from the Camaro if somebody's in a pinch and wants to try it. It's pretty rusty but likely works and is identical to the one on my VX. You pay shipping and $20 if it works.
    I went everywhere in town looking for an EGR gasket and didn't find one, then found one right on top of my toolbox I had leftover from my 93 Jimmy. The 93 Jimmy's EGR is shaped differently but would probably work. I just looked at my father-in-law's 2000 S-10 tonight and it is just like the Camaro's EGR.
    In any case, you can probably find one at a bone yard cheap enough if it really needs replacing. Usually they just need a good cleaning with carb cleaner and a screwdriver.
    Here's another tip I learned about on the S-10 forums -- you can get an EGR gasket with a screen on the exhaust side that helps prevent clogging due to larger pieces of carbon getting blown through it.
    I bought one for the Jimmy from Rob Stark (which is why I had an extra). I can't find a link from his site but Google found a couple others:
    http://www.sherco-auto.com/klean.htm
    http://www.northernautoparts.com/Pro...ctModelId=7514
    The real deal: http://www.tomco-inc.com/
    Edit: added the Tomco link.
    Jul 2004
    2000 Black VX 0363
    before you go and replace it, I'd try giving both the EGR and the pipe a good dousing with O2-safe carb cleaner. Go get the light reset and see if it comes back.
    2000 Black VX 105k
    2001, Proton Yellow, #0580
    Harbor Freight has an OBDII meter on sale:
    http://www.harborfreight.com/cpi/cta...emnumber=46030
    I've got one - it works as designed.
    The EGR is pretty easy to clean yourself - like Maugan says, try that first (careful with the right bolt - if you drop it it's hard to find). I sometimes see OEM replacements on eBay for around $100 (the current listings are more like $200).
    -- John
    Aug 2004
    Quote Originally Posted by Maugan_VX
    I think this is what I'm going to try first. I'm no mechanic, but my valve looked brand new, and I'm having a difficult time looking at it and seeing "defective." The VX is not my 'daily driver,' so I have the luxury of time, but I'll try to get this done over or before the weekend and let everyone know my results. Really appreciate the help from everyone.
    Jul 2004
    2000 Black VX 0363
    just watchout for that one bolt... I recommend loosenning it as much as you can by finger then using a shop magnet to remove it. Then using the magnet/finger combo to put the bolt back in.
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. Check Engine Light...
    By dobie3 in forum VX Troubleshooting...
    Last Post: 12/11/2003, 02:45 PM
  5. Check engine light just came on...
    By Inaba in forum VX Troubleshooting...
    Last Post: 06/28/2003, 10:52 AM
