I believe the problem with my VX is in the transfer case .......
the transfer case may be sending too much power to the front end ....... (when it should not be) ......
this is especially noticeable/problem when making slow speed turns - you can feel the front and rear end 'fighting' ...... hear the additional drive train whine ........ similar to when 4wd low is engaged ..........
