Results 1 to 15 of 39
Thread: "High-pitched howling" noise while turning?
    Apr 2003
    Quote Originally Posted by Apostle
    Cat stuck in the rear well?
    Cats screech... dogs howl...
    With that said...
    Dog stuck in the rear well?
    Mar 2004
    2000 Firefox Red 0758
    I believe the problem with my VX is in the transfer case .......
    the transfer case may be sending too much power to the front end ....... (when it should not be) ......
    this is especially noticeable/problem when making slow speed turns - you can feel the front and rear end 'fighting' ...... hear the additional drive train whine ........ similar to when 4wd low is engaged ..........
    Still the same issues here. No solution huh?
    Dec 2004
    Dude you totally scared me resurrecting this thread!
    I should update, though - that sound finally went away for me. My post above (#32) said that it came back even after the rear diff rebuild and new tires. Well it did, but just a couple of times, and it's been silent ever since.
    Btw, my problem was not the one described by t2p in post #37 - my screech sound was definitely coming from the back end.
  1. "Crackling type noise"
    By JNUVX in forum VX Troubleshooting...
    Last Post: 10/25/2011, 07:49 PM
  2. Replies: 35
  3. Replies: 36
  4. weird howling noise in my vx
    By protonvxmatt in forum VX Troubleshooting...
    Last Post: 01/02/2007, 09:11 AM
  5. High pitched chirp or squeak
    Last Post: 01/29/2006, 01:26 AM
