Not to hijack, but I was going to start an almost identical thread today…
Two times now, two days in a row - while turning left at low speed - I’ve experienced a moaning/groaning sound that seems to be coming from the front passenger-side.
The first time it happened, I was turning onto a street in my neighborhood, with the brakes lightly applied – and I simply assumed that it must be related to my upcoming/impending brake and rotor replacement… But yesterday it happened again as I was rounding a corner, approaching the drive-thru at my bank – without the brakes applied at all.
Both instances were left turns, at low speed, with a slight surface transition that corresponded with some mild suspension travel. --- After it happened the second time, I checked my 255/70/16 tire clearance with the cladding (Nope, that wasn’t it)… I also checked for any looseness in the hub and/or suspension components (Not as far as I can tell)… So, about the only thing that still comes to mind is that I have an OEM Shock on its way out, but I really don't know.
Could GAZ and I perhaps be experiencing the same problem, only at different ends of the vehicle?
