Results 1 to 14 of 14
Thread: Brake line repair?
    Aug 2003
    2001,White,Rodeo Sport,
    Why would you replace a peice of hard line with an ss braided line. Isn't the purpose of SS Braided lines to be used in place where a hard line cannot be used and to get better performance than a rubber line?
    Dec 2002
    '01 Ironman
    Well it is a rear brake line, and it would be a pain to pull out and especially getting it back in without any tweaks in the line. Soo I am replacing the entire hose with braided SS. I'm not sure how they plan on doing it but I am guessing they will just cut the fitting's off my existing line and attatch them to the braided line.
    Ruflyf, that is a good question.... I guess I will just find out the hard way.
    Volume311 I am replacing it because it is spewing brake fluid... going through a bottle every 3 days
    A rear brake line would be even easier than a front. Each one only runs half the length of the axle.
    You might want to take another look at that.
    I am away from my manuals, but I'm fairly certain that there's a single rubber line that drops onto the axle, and from there it is split into two hardlines, one for each side.
    Dec 2002
    '01 Ironman
    I will look again but I am fairly certain that it runs the entire length of the vehicle above EVERYTHING. And above a box in the back passenged side that will not come off. If there is a flange/some type of connection between there.... I didn't see it.
  1. Broken brake line
    By RAZ in forum VX Troubleshooting...
    Last Post: 11/15/2014, 07:05 AM
  3. Brake line failure
    Last Post: 09/25/2010, 05:30 AM
  4. Any experiance with these brake line kits??
    By morgan-tec in forum VX Modifications...
    Last Post: 04/15/2005, 03:46 PM
  5. Brake line size? Ditching ABS...
    By coachreed in forum VX Modifications...
    Last Post: 04/04/2004, 04:46 PM
