Results 1 to 14 of 14
Thread: Brake line repair?
    Dec 2002
    '01 Ironman
    Brake line repair?
    Does anyone know if/how you can repair a metal brake line? I had a shock break which dented the brake line and has since turned into a leak.
    If you can't think of a way... or it just shouldn't be done... how the heck would you replace it/get the new one in there? Is the only way trying to lift the body and squeeze it in/out there? I don't have the money to hand this off to a shop so any suggestions would help.
    I am not at home and don't have my Vehicross CD available, how does it say to do it on the CD? This is a rear brake line, it runs down the passenger side and is closest to the center of the vehicle.
    2001 Proton VX 0790
    You can do a repair if you have a flairing tool, and a tubing cutter. New unbent brake lines are sold at many parts stores. You cut the line, flare it, then use a fitting to join them.
    If you aren't comfortable doing this, pay a real mechanic to do it.
    John C.
    May 2004
    99 Astral Silver w/ SC
    Hey Alaska, was just looking through the manual, as for repairing it, I didnt see anything on the subject. I would think with something to flare the existing line, that it would be possible to cut out the leak and put a new piece in.
    As for removal and installing the brake pipe, the vx disc is very basic, saying that there is just a couple plastic clips to undo near a cross member. And of course both ends of the pipe, I have no idea if a replacement would be pre bent or if it can be ordered in straight lengths
    May 2004
    Damn, hotsauce you type faster than I do lol
    Dec 2002
    '01 Ironman
    Thanks Guys!
    Thanks for the suggestions, however I found a much better way of going about it.... a local tubing place will make me a steel braded line for it, I can just cut the existing one to get it out, bring it in so they can get the measurements and fittings, then run the new one on through.
    They would still need to cut and flare the old line in order to attach your braided flexible line.
    Since it's a front brake line, it shouldn't be too long. There's no reason why you can't find a suitable replacement from a junked Trooper.
    I have the bending/cutting/flaring tools all in my toolbox (yet I refuse to fix this leaky MC). I/we need to get together someday. I still want that hoodscoop
    May 2004
    Are you talking about making the entire run of that brake pipe from braided flex line? If so, just a thought so take it for what its worth; would it be a good idea to have different lines for each side? Maybe different volumes of fluid on each side would affect the braking?
    For ex. they always say for brake pads change both sides at the same time. Just wondering if that could cause problems later down the road for ya.
    O.K., I just crawled out from under there...
    You didn't break A rear brake line (they are located on the rear side of the axle, away from the shocks). You broke THE rear brake line. If it broke near the top shock mount, you are seriously lucky that you didn't take out one of the 3 fuel lines in the same area (actually mounted right next to that brake line).
    You can take it in and get it spliced for a few bucks. A good brake shop will be able to fit you for a hardline and compression fittings for less than $75 Alaska dollars.
    You are 100% correct, to remove that entire line and replace it (with one from another VX or a SWB/2dr Trooper) would be a PITA. It is one piece all the way to the ABS module. Also, I've found that the plastic clips that hold those hardlines to the frame tend to harden and get brittle. Trying to pop out a line will break it, and then you'll be left with a floppy brake line. You'd need to get all new clips as well as a new line.
    I would still stick with a hardline repair unless the break is on or very near a bend.
    Dec 2002
    '01 Ironman
    Yup thats the one THE brake line
    The break is in between 2 90* bends but is on a straight section (4-5" long) just not much room to work with as it is not just a hole but a dent that is 2" long that has sprung a leak. I would be happy to pay a shop $75 for a hardline repair but I don't think any shop would do it due to liability issues, but I may just stop by a few shops to see what they say today.
    Dec 2002
    2001 Ebony 0177
    Maybe get the whole length, just use the rear section...put the joint in any accessable area forward of the dent. Or as someone else said, bend the needed section yourself (trial an error a bit, but not that hard) Just keep compression fitting joints in easy places
  1. Broken brake line
    By RAZ in forum VX Troubleshooting...
    Last Post: 11/15/2014, 06:05 AM
    Last Post: 12/14/2011, 01:15 PM
  3. Brake line failure
    Last Post: 09/25/2010, 04:30 AM
  4. Any experiance with these brake line kits??
    By morgan-tec in forum VX Modifications...
    Last Post: 04/15/2005, 02:46 PM
  5. Brake line size? Ditching ABS...
    By coachreed in forum VX Modifications...
    Last Post: 04/04/2004, 03:46 PM
