Results 1 to 4 of 4
Thread: bearing problem
    Mar 2006
    not yet
    bearing problem
    I have read that the Vehicross engine is prone to bearing failure around 60,000 miles.
    Is this true ?
    Thanks
    Dave
    99' Astral Silver
    This has happened to only a handfull of members here but I wouldn't go as far as to say it's "prone" to doing this. It's not a common problem but one that has been reported periodically.
    I'm sure others will chime in with more useful information but to answer your question, no, this is not a common thing to have happen
    Live Free or DIE!
    Mar 2006
    not yet
    Thank you for your response. I was hoping this was the case.
    Apr 2005
    2000, burgundy, 2341
    mine spun a rod bearing at 70.000 miles over the winter time. And i was told by a mechanic that he had replaced a trooper engine (which is the same as ours) with a factory reman and it spun a bearing after 40.000 and the first engine did the same thing.
  1. How Much For Wheel Bearing Replacement?
    By bartmanS4 in forum VX Talk...
    Last Post: 03/25/2014, 01:58 PM
  2. does this sound like a wheel bearing?
    By spitfire5454 in forum VX Troubleshooting...
    Last Post: 09/26/2008, 09:47 PM
  3. Bearing re-pack help.
    By MSHardeman in forum VX Troubleshooting...
    Last Post: 05/08/2008, 01:54 PM
  4. Another Wheel Bearing story (and a tip or two)
    By kinnaq in forum VX Troubleshooting...
    Last Post: 07/19/2007, 11:32 AM
  5. Bearing Repack help
    By Ron Pfeiffer in forum VX Troubleshooting...
    Last Post: 11/17/2004, 01:31 PM
