Results 1 to 10 of 10
Thread: slow starting
    Angry slow starting
    Ive had my vx for about two weeks... its an 01, 41k miles. friday night i drove it from philly to frederick md (about 150 miles) cruising around 75, then a few short short trips friday night, few short trips saturday without any problems, then saturday night, the vx had been sitting for about an hour and i went to start it and there was a lot of hesitation starting, felt like the battery was dying, i turned it off and it fired up again with no trouble at all,checked the oil the next morning, looked fine..... no other problems during the weekend then tonight itd been sitting for about an hour and a half after about an 18 mile highway trip, had the same problem where it hesitated to start, turned off, turned back on, it was better.. but still not good, didnt feel any power loss driving it.... any ideas? ive got about 12 days left on my dealer warranty.. so if this is the start of something bigger i wanna get it taken care of asap
    Dec 2004
    Get that battery tested. Good luck!
    May 2004
    99 Astral Silver w/ SC
    corrosion on the terminals maybe? I dont think its ignition switch related since its making contact. I agree with VehiGAZ, battery or corrosion, maybe battery water lvl.
    i wasnt sure if it was battery related or not since it seems like it only happens every so often, but ill try cleaning the terminals and then a good battery if that doesnt work.. but just in case.. any other ideas? i was wondering about temperatures because it only seems to happen if i start it up while the engine is between cold and normal running temp
    Arrow
    From your description I'm not sure if it's turning over slowly or if it's turning over a long time before it fires.
    Right after I got mine, It would start right up when cold, but after it warmed up it would crank & crank for 15-20 seconds before it would finally fire.
    Took it to the Isuzu shop & they replaced the fuel pressure regulator (they indicated that this wasn't the first time they had seen this prob.)
    She's been running great ever since. Hope any of this helps.
    Ldub
    its doing a little of both, cranking for longer than normal (4-7 seconds maybe) then once it turns over it will sputter and sound like its going to die for a second then the rpms will jump and even out.. fuel pressure definately sounds like something that would be causing it, ill have to try giving it some extra gas and see if that helps... thanks for the reply! I'll let you know what I figure out
    Aug 2003
    2001,White,Rodeo Sport,
    Yep, sounds like an FPR. had the same starting/sputtering/stalling problem sometime ago. Part costs ~$50 from St.Charles, but since you're still on the warranty get them to take care of it.
    May 2003
    Wink
    My VX would start up normal when cold (say, after sitting overnight). However, if after you were driving you stopped for gas or hit a store and then went to start it up..it would take 2-3 attempts of cranking over before it would finally start. I too changed the fuel pressure regulator and it has completely resolved the issue. Link below shows the regulator:
    http://www.drivewerks.com/cgi-bin/pp...sure+Regulator
    awesome, thanks to everyone who replied!... anyone know how to replace the fuel pressure regulator? haha or is it worth just taking to the dealer
    Buy a good quality internal retaining ring set of pliers - preferrably with 45 and/or 90 degree tips. With engine off and cool, release pressure on the fuel rail by covering the schrader valve with a cloth and pushing the center of the valve (looks like a bicycle valve) until no more fuel runs out.
    Take the pliers and squeeze the clip while lifting. Put lots of rags around the regulator to catch ring if it gets loose (which it can) then reomve the old one and replace with the new. Pay strict attention to part order. Instructions are also in the workshop cd you can download from my site or send a me an email with your address and I drop one in the post to you.
  1. Going Drag racing in the slow lane!
    By ohiovx in forum VX Talk...
    Last Post: 11/07/2015, 11:20 AM
  2. Driver's Window slow to raise
    By curiouswords in forum VX Talk...
    Last Post: 05/11/2006, 09:41 AM
  3. Slow/dead windows
    By Apostle in forum VX Troubleshooting...
    Last Post: 12/22/2003, 04:40 PM
  4. Tire with slow leak
    By WyrreJ in forum VX Troubleshooting...
    Last Post: 11/25/2003, 10:27 PM
  5. Vmag dying a slow death?
    By Panther_Black_VX in forum VX Talk...
    Last Post: 05/28/2003, 09:31 AM
