Results 1 to 15 of 15
Thread: rear door light?
    Dec 2004
    If you think the lack of a rear dome light is annoying, wait until you have to take the keys out of the ignition to open the rear door five or six times! The fix for this is a fix for BOTH problems... get Tone's rear door popper kit (see http://tonemonday.com). A LOT of the people on this board have gotten and installed it - it is almost a required mod for the VX.
    Benefits:
    - gives you a push-button switch for the dash or center console that will pop open the rear door
    - wires the rear door into the alarm system (no, it is not connected to the alarm system normally)
    - makes the dome light turn on when the rear door is opened
    These are really surprisingly bad shortcomings of the stock VX design, but they are easily fixed with the door popper kit. You could collect all of the parts yourself for cheaper than the $130 Tone is charging, but his kit is complete and it works.
    Good luck, and welcome to the family!
    May 2004
    99 Astral Silver w/ SC
    I agree with Viehigaz, one of the best mods that was done to mine. If I remember correctly it has a trooper domelight in the back and also has a manual on/off switch on the light itself. Just make sure you put it back far enough so the rear seats dont cast a shadow of the area your trying to light up.
    '99
    Those are great mods that you'll love. In the meantime, there's no need to take the key out of the ignition to get in the back door or back into your home. Get a two-part key chain and keep a second ignition key with your other keys. You could even keep it running and lock the door as you make a quick stop at a mini-mart.
    Mark
    May 2004
    Used to own #777
    I used a 1st gen Rodeo rear cargo light in Ruflyf's VX. It was small and had a built in switch. Wiring was fairly easy, just remember that most dome lights use a switched ground (from the door pin switch) and constant positive. This means that for an on-off-auto switch you'd run one postive wire, one ground wire, and one wire from the door pin switch (switched ground). You may be able to connect all 3 easily to the front dome light, but in his VX the sunroof was in the way. I just installed it when the door popper was being installed. Constant 12V was easy, ground was easy, and I just connected the switched ground to the new rear door pin switch.
    -Tad
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    I’ve been catching up on my VX reading some lately – Glad I spotted this one.
    I really like the idea of combining Tad’s rear dome light fix with Tone’s popper – Hopefully I’ll get around to doing both soon…
    Those weekly Friday night Wally World load-outs are starting to get pretty old without illumination –-- And I finally realized why the popper is such a cool mod when I was standing at the back door with my keys in my right hand, and a 12-count case of ATF under my left arm… (3-2-1-) “DUH!”
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
    Nov 2002
    2001 Dragon #0467
    Talking Rear Dome Light
    Many here have done this Mod:
    Isuzu Impuse dome light Part# 8-94111-248-0
    Same exact dome light as Vehicross Part# 8-97153-956-0, except in black.
    I found this one on Ebay, Brand New in box for $10.
    Also put in a pair of #T-6 - PIAA Xtreme White bulbs #19223
    It's wired in parallel with the center dome light.
    _______
    rickshaw
    Original Owner
    #467 01' Dragon
    Sep 2003
    Nice! - I really like the clean, matching look
    2001, Kaiser Silver, #988
    Very nicely done!!
    Just a question or two...
    1) So you ran your own wires connected off from the existing front dome light to the back...what kind and how many wires were used?
    2) How did you get the wires to go under the headliner (without drastically removing anything or destroying what's under the liner, like the adhesive,etc)?
    3) Is the new light just mounted to the headliner or is it bolted to the metal underneath somehow?
    Appreciate the info!!
    Quote Originally Posted by rickshaw
    _______
    rickshaw
    Original Owner
    #467 01' Dragon
  1. New rear door
    Last Post: 08/06/2012, 04:47 AM
  2. Rear cargo light + underhood light
    Last Post: 05/29/2010, 08:00 AM
  3. rear door knobs
    By bigkoala1 in forum VX Troubleshooting...
    Last Post: 02/25/2008, 07:49 PM
  4. Can you ID this rattle at rear door??
    By Kenny in forum VX Troubleshooting...
    Last Post: 08/11/2006, 04:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
