Results 1 to 15 of 18
Thread: Rear / Clear side marker lense post
Threaded View
    99' Astral Silver
    Just bringing over some good info from the other board
    This post is for anyone looking to replace the Red Rear Side markers on the back left and right sides of your VX.
    I discovered a while ago that the side marker lense for the older style miata will fit on the VX to give you some lighting & styling options.
    Here are some shots of the miata lense on the miata:
    http://www.finishlineperformance.com...ion&key=EL1016
    The lense above costs $41.80
    More details on the lenses below, this is a quote from thier site. Apparently this is a full lamp assebly replacement. These are: $209.95 for 4 as you have to buy them as a set but I bet they'd look sweet!!!! :
    Got Chrome? Give your Miata a vintage flair with this Chrome Side Marker Lamp set. Specifically designed and engineered to fit into the existing side marker openings using hidden screws to provide a flush clean look. Lamps are genuine Hella Amber LED inserts. This set will complete your entire Miata with all lamps, wiring and instructions included.
    I imagine the set of 4 above means it comes with front and back marker replacements for the miata so I suspect the fronts have orange bulbs and the rears have red. Something to keep in mind if you order them. I am not sure how easy it woould be or if it is possible to swap the orange bulbs to red. I believe the front and rear markers are the same so it may be possible for a few folks to group buy or split a set between two people and one wuold be stuck having to sawp the orange to red bulbs IF that is a possibility?
    http://www.finishlineperformance.com...ion&key=EL1008
    Proof they fit: this is a shot of the marker on a miata, if you check the part #'s in this pic and compare them to your VX lense you will see they are the same.
    They have your basic clear ones like Cyrk has here:
    http://www.imagestation.com/picture/...7/fdbd06db.jpg
    Then you have some style options as you see below:
    Live Free or DIE!
  1. Klearz silver side marker housing question
    By atilla_the_fun in forum VX Modifications...
    Last Post: 02/03/2011, 08:10 AM
  2. Clear Side Marker Lights & Bra!!!!
    By littlewing2 in forum VX Talk...
    Last Post: 11/01/2008, 10:15 AM
  3. Rear Side Marker Blinker Kit
    By tysamigo in forum VX Modifications...
    Last Post: 05/18/2007, 03:41 AM
  4. Clear Side Marker???
    By marximus in forum VX Talk...
    Last Post: 11/01/2004, 03:49 PM
  5. Clear marker and bumper lens??
    By Benny in forum VX Talk...
    Last Post: 01/08/2003, 04:41 PM
