Decided to do a little mod to my guage cluster while I was there (I removed the bottom panel of the driver's side dash instead of just taking out the one screw as suggested, about as quick and a lot less fuss trying to thread that wire). My plan was to take out the cluster, take the clear cover off and put some chrome pinstripe that I found around the 2 large guages. Bad news - the clear cover is glued to the cluster surround. I tried getting it apart, but cracked a little edge (that isn't visible, thankfully!). Had to give up until I can see if the clear part is available by itself. I thought a single chrome stripe around the 2 guages would liven things up a bit - guess I'll have to wait!! At least I got to experience taking the dash trim off and see what's behind there!
>>> Split this thread from here
WSG
