I have a '99 #86 130k miles. This vehicross has served almost perfectly during its years of stomping. Two months ago it began leaking tranny fluid and motor oil. Well, money is a hard thing to come by lately so it had to sit for 6 weeks while I saved. When it made it to the mechanic the trouble turned out to be 2 leaking transmisson cooler lines and a gasket somewhere near the worm drive. 2 of the tires were looking funky so I had them replaced also. Picked it up from the mechanic's and it worked fine. A week later while highway driving it began to rain. TOD went out red check light came on. Now the TOD works intermitintly. At 10 mph it tries to engage but it seems to be confused providing erratic compensations. When TOD fails to engage check light comes on. Also when TOD is off and sharp turn is made I get that noise and binding you get when you switch from 4lo to 4hi. TOD sometimes engages and disengages at high speed affecting stability. Where should I start looking for the problem?
TIRES? Bridgestone Dualer AT P245 70/R16 106S
