Results 1 to 8 of 8
Thread: High pitch whine on idle
    My VX started making a high-pitch noise/whine when I don't press the gas. Basically when I start it cold there is no noise... then few minutes later as it warms up it starts making a high-pitch constant noise coming from somewhere in or around the engine. As soon as I give it some gas it goes away but comes back when I let go or idle... any ideas wht could be a problem? It is pretty loud so I think it could be something serious... I can't quite pin-point where exactly it is coming from. Any suggestions are appreciated.
    Thanks
    Since you mentioned no idle or other engine issues, I would say it is a bearing on the alternator, power steering pump, or ac compressor. It could also be the fan clutch. Have someone look under the hood and listen while you give it a little gas and the area of the whine should be relatively easy to isolate.
    Thanks Tone for the suggestions. I actually tried to identify the source of the noise myself - I opened the hood and tried to find where the noise is coming from while on idle and could not pin-point it. It seems that it is coming from the right side of the engine (if you are looking from the front) but not certain... when I press on the gas cable in the hood to give it some juice the noise goes away but returns as soon as I let go.
    AC or power steering then.
    1999, Ebony Black, VX ,1976
    Check the hose that connects to the pcv valve. A vacuum leak will make a noise like that. Shawn
    1COOLVX
    Jan 2006
    1999,Satin Black and bedliner
    If you can't tell what accesory it is comming from, get a dowel or broom handle 2-3 ft long. With the enging running, and without getting the dowel wrapped in the belt or smacked by the fan, place one end of the dowel on the accesory or it's mount. Then cup your ear to the other end of your dowel. The accesory that the noise is comming from will be noticeably louder.
    May 2004
    99 Astral Silver w/ SC
    Mustangs idea works with pvc pipe also, any diameter. Just BE CAREFULL not to get close to a belt or fan. Helps to plug the other ear also, btw
    May 2005
    1999/White-Ironman-0648
    You can try replacing the oil filter..sounds funny, but i have had 1 do the same thing, also had one on my amigo do the same thing,each time it was the oil filter, i couldnt believe it either!!
    From The Mind Of Lashsquat
  1. High Pitch Noise associated with keyless entry?
    By logan1079 in forum VX Troubleshooting...
    Last Post: 01/14/2009, 07:51 PM
  2. High idle/ high power steering pressure?
    Last Post: 09/22/2007, 04:21 PM
  3. High pitch whistle
    By UNEVEN THOUGHTS in forum VX Troubleshooting...
    Last Post: 05/18/2005, 01:53 PM
  4. High pitch whine at 60+
    By PBR in forum VX Troubleshooting...
    Last Post: 04/03/2003, 06:42 PM
  5. High pitch noise even when NO KEY in the ignition - any ideas??
    By Yefim in forum VX Troubleshooting...
    Last Post: 12/18/2002, 09:52 AM
