still building these? Think it can handle 2400 watts? (not that I ever really pound it THAT hard, but you know sometimes the kids in the civics need a lesson)
Teach them a lesson or sound just as bad and annoying as them?
I am NOT too sure this box will suffice that much punch. I am pushing a JLAudio 200w through my 12" JLAudio sub in this box and the port already pumps out a crap-ton of air. Excellent quality box but best used for precision tuning, not trunk thumping.
Shawn,
With the carpeted box, does it replace the OEM spare cover or does the cover go back over your box?
Only a few subs I know of that can handle that much power and they are WAY to deep to fit in a VX's rear door.
Shawn,
Can you build the box to mount a subwoofer I already have? It's a 10 inch Illusion sub.
I have forgotten the specs on it, I am not sure if 1.25 cu/ft is enough. I had a sponsorship with PYLE, (I know), and they installed there best comp stuff. That was a few years ago and now I am stripping it out. I have NEVER even gotten close to full power, maybe 1/2 of what it is capable only a couple of times. At 1/2 capability it was impossible to breath and it gave you a case of vertigo.
EDIT:
NM I need 3.678 cu/ft
Shawn,
I'm trying to find it. It's in my basement somewhere...you should see my basement! I'd like to be the forth person but since this would be sort of a custom hole you may not be able to discount it for me.
FYI, The spare cover will fit over the installed box as well. You need to trim the ribs on the backside of the cover and of course, cut a hole for your sub (makes a WONDERFUL vibrating/rattling cover if you don't. STill very happy after a couple years with it. Great work by Shawn.
Hey psychos2, would a Pioneer Shallow TS-SW3041D 12" be able to be flush mounted to the box? I do not know how deep your box is.
Also would you be able to make it? I always wanted to buy one, but kept forgetting about it and I would really like what little cargo space back!
