Results 1 to 15 of 17
Thread: Lifting help/Advice
    It only took me 4 hours at home! A shop should be able to do it in way under that. But I say skip the shop and do it yourself. I am by no means a super mechanic...I change my oil and can do the basics and thats about it. On the scale of 1-10 on the difficulty scale, I'd say this is a 3-4 at the most. As for the tools needed they are going to be way cheaper to buy than what the shop will charge for the install. I bought my springs at Rocky Road Off Road for about $125. Nothing else is needed. If you stick with 31 inch tires you do need bump stop extensions. If you go bigger you will need to do a few other mods...major fender trimming and some metal rearanging in the fender wells. The stock shocks will work just fine...mine still do. After doing the project you can have another drink and give yourself a big pat on the back to go with it! :_drool:
    Just print up my how-to and follow the instructions, its all pretty well laid out. It is not difficult at all then you'll be a proud owner of a whole new VX! Once you get back on your feet from the hurricane loss hopefully you'll be able to join us in Moab to test out that lift!
    Dec 2002
    '01 Ironman
    Yah I was going high to make sure he had enough before he went and did it. Didn't want to low ball it and have him take it to the shop and get a bigger bill.
    Sep 2005
    '99, Ebony, VX, 1742
    Thumbs up Thanks you guys!
    Tri and Alaska,
    You two have been a huge help! Thanks so much for all the input! I'm gonna go check out the sites you both referred me to, and see if I can get everything ordered. I basically see that all I'm really going to need are the 912 springs and a set of new rear shocks...right? Whats all the stuff I saw about some calmini (or however you spell it) lift kit? Am I going to need to get that as well, or is that totally different? Thanks again for everything guys! I'll take some before and after pics once this thing gets started and hopefully it will all work out! I owe you guys big time!
    SRCHN
    Triathelete's guide is really excellent.
    This is totally a DIY job, and you can't put a price on getting to know your truck's suspension first hand.
    I'd recommend some extended brake lines as well as the springs. It's only a lift of 2" or so, but the extended lines will give you a little more room to play.
    Unless you have experience bleeding ABS brake systems, you might want to hand the brake lines over to a shop (should you decide to do the lift yourself).
    If your factory shocks are in good shape they will do the job...no need to repale them. Only need to invest in the springs. Good luck.
    99 white ironman
    sorry to jack this thread, but since you got into stock shocks, was thinking about doing the same but I have the rancho rs9000x shocks installed... I don't see why they wouldn't work but any suggestions, opinions?
    Sep 2005
    Hey Tri,
    I just finished printing up the instructions on your lift advice. Got a quick quesiton...(and thanks for the tip on the shocks by the way). You wouldnt happen to still have the pics of each step of the lifting process would ya? I clicked on the link and I saw that thread was kinda old and the pictures no longer appear to be there. If you still had them by chance I would really appreciate it. Thanks again guys for everything!
    If you guys are ever down in the FL panhandle, ya gotta place to stay!
    SRCHN
  1. Lifting the VX
    Last Post: 02/23/2008, 04:33 AM
  2. Lifting the VX
    By dtruax in forum General Tips...
    Last Post: 01/11/2006, 07:37 PM
  3. Big lifting for the VX
    By wrestler11 in forum VX Modifications...
    Last Post: 10/24/2005, 03:23 PM
  4. Lifting the VX, need advice first
    By VehiX in forum VX Talk...
    Last Post: 04/21/2005, 08:56 PM
  5. Lifting the VX
    By NC_VX in forum VX Talk...
    Last Post: 06/24/2003, 02:47 PM
