Alright, got some issues with some suspension noise..
A few weeks ago I took out my front axle and installed Darlington diff drop brackets (which fit very well if anybody is interested) and now I have a noise.
About the noise:
It sounds like something is moving around, shaking, not a rattle but bigger. It sounds like I hung a weight from my car, and when i go over bumps it pounds up and down alittle. It is really hard to describe! It's not a terribly alarming sound, maybe a sound I would expect a '77 3/4 pickup to make, but not a little 1999 isuzu.
It's not rythmic, it can't really be felt in the steering wheel, and it doesn't matter what speed I go as long as the bump is big enough. I got under the vx several times and checked everything and nothing is out of place.
I retorqued all the bolts I removed and checked them several times, and no... I didn't have any parts left over after the install![]()
Any Ideas what this could be??
I was thinking a loose ball joint and my wheel bearings are pretty bad but other than that I have no idea.
Any help would be appreciated
bobmumgaard
