Results 1 to 4 of 4
Thread: Code: P1640
    '99 SC Ebony #1961
    Code: P1640
    Pulled this code today, anyone got a clue on what it is?
    P1640
    ODM 1 Input Voltage High (Except 1998 Rodeo)
    ODM Output ‘‘A’’ Circuit Fault (1998 Rodeo)
    '99 SC Ebony #1961
    Bump... anyone?? Guess I bring her to the dealership... blah
    '99 Astral #1977
    I am searching through misc. codes myself and I happen to come across this code. Apparently there are ECM Quad Drivers 1 thru 4. Driver 1 sends commands to the EGR. It is not Isuzu specific, but the codes appear to be pretty generic and apply to OBD II. And I know it's pretty vague, but I hope it helps.
    EDIT***
    Strike all that bullhockey above. It is too generic. But then Isuzus definition is even more crap. A P1640 code is just an improper voltage was detected on an output driver module. But doesn't say which One. It will clear itself after 40 consecutive warm up cycles without another fault. They go on to say to check for a poor connection at the ECM, a damaged PCM harness, or a poor connection at the insrrument cluster, canister purge solenoid, A/C clutch relay. Sounds like they're gonna have your running in circles! Anyway, it's a start.
    RichD
    '99 SC Ebony #1961
    thanks much... it's a start.
  1. P1860 code
    By AndyC in forum VX Troubleshooting...
    Last Post: 08/27/2013, 09:19 AM
  2. Abs Code 35
    By johnny010 in forum VX Troubleshooting...
    Last Post: 01/08/2009, 11:11 AM
  3. TOD throwing code 13
    Last Post: 02/10/2007, 02:54 PM
  4. PO 440 - Code
    Last Post: 01/03/2006, 09:21 PM
  5. Cel Code 405?????
    By Mr. I-MAN in forum VX Modifications...
    Last Post: 09/10/2004, 09:13 AM
