Results 1 to 13 of 13
Thread: Vibration when turning
    Guys, whenever I start moving with front wheels turned left or right, a short vibration comes from the rear part of the vehicle...It doesn't happen when making turns while in motion, only when accelerating from a complete stop, say at an intersection.
    From what I read up in the forum, some of you had somewhat a similar problem, but that happenned when the car was moving.
    I've been told that it must be an automatic differential lock engaging itself (for no apparent reason though) and that this should not bother me for now, however I feel very uncomfortable with this vibration occuring each time I take off while front wheels are turning.
    I got the car checked out but the mechanic told me that there are no visible problems, and that to properly understand what's going on, differential should be removed and inspected. He mentioned that may be a wrong type of lubricant in the axle is the reason for the vibrating sound...could it really be the case?
    Please help.
    Nov 2002
    Arrow
    If you're tight turning from a stop it's most like the rear differential, which is very common for short-wheelbase vehicles like the VX and nothing to concern yourself over. My '93 Trooper RS, also SWB, would do the same thing.
    Well, I wouldn't be worried but that only started to occur recently. I haven't had this problem earlier regardless of how tight the turn was...And I have to admit that it happens not only in tight turns, but in ANY turns. Is it possible that something else is causing it?
    Arrow
    Changing the diff. fluid & adding new LSD additive MAY help somewhat...It's easy & inexpensive. Depending on mileage, It probably needs to be done anyway.
    Ldub
    Ldub, thanks - do you know the type/brand of fluid and additive that should be used?
    Well, i have actually checked the type of lube that's in there now. It's Mobil's 75W90, which according to the manufacturer's website, is excellent for LSDs. However, I guess it won't hurt if a proper LS additive is added...the question is what would be the proper additive...?
    Nov 2002
    Arrow
    Mobil-1 gear oil is a little too slippery for the Isuzu LSD, so be sure to use additive. If you need to locate drain and fill points, check my gallery for photos of the diff.
    Arrow
    Quote Originally Posted by Shortstop
    Ldub, thanks - do you know the type/brand of fluid and additive that should be used...the question is what would be the proper additive...?
    I use all Amzoil products & have found the LSD additive at my local NAPA, though they did have to order it. Being syn. it should mix w/ mobil 1 products...maybe Joe Black has some input on befouling Mobile 1 products w/ Amzoil product
    I would imagine most other manufacturers offer LSD additive.
    Ldub
  1. Drivetrain vibration
    Last Post: 03/11/2016, 05:19 PM
  2. Arg! What's that sound and vibration!
    By Slideways in forum VX Talk...
    Last Post: 08/26/2012, 08:11 AM
  3. Vibration at 60 mph (tires balanced already)
    By MustangO4 in forum VX Troubleshooting...
    Last Post: 11/18/2011, 03:11 PM
  4. VIBRATION !,Any ideas?
    By Ldub in forum VX Troubleshooting...
    Last Post: 08/31/2006, 07:32 PM
  5. vibration while steering
    By james1_10018 in forum VX Troubleshooting...
    Last Post: 08/10/2005, 07:05 AM
