Well fixed my Window longish
Man that was fun. I had to use all the fixes I found and some. First I widened the track better but still binding. As a tip be sure to widen it all the way up it's that last top part were it seems to grab the most. Then I bored out the front window connection where the bolt goes in and put a metal shim in to raise the window a little in the front. Again better but not perfect. I finally noticed that if I put the slightest amount of down pressure on the back of the window it would go up and down perfectly. So I played with it a bit to figure out how much weight it would need on the back of the window with a fish scale and went to the hard ware store to find something about the same weight to slap on there. 15 min later I came home with a heavy duty door hinge. I bent it so it would close on the bottom of the window with no gap then used Amazing Goop which you can get from Lowes and yes it glues anything permanently. I let it set and tried it out and now it's perfect. Up and down with no binding at all and the extra weight doesn't make the window go any slower or put to much stress on the motor ( granted it wasn't much weight and it's much less resistance than the window binding. Well, I thought I would share TTYL.
So what did you call that thing again?
