Results 1 to 8 of 8
Thread: security/alarm issues
    2001,BLACK,VX,0163
    My alarm stopped working. The red LED on the dash stays on continously and my remote(s)/fob(s) won't lock/unlock the doors now.
    Any ideas or help? The dealer suggests that there is a short somewhere and want $90 + to trace it....
    Many thanks!
    2000, foxfire red, 0474
    Is this not typical of valet mode? I believe you can reset it by the switch below the hood pull, and by the remote. I just can't recall the combination of presses.
    Max.
    Thanked: 7
    Try resetting it -
    The alarm manual that comes with the VX only shows how to program the alarm with respect to options. If the remote is no longer recognized by the alarm, it will need to be ’taught’. Depress and hold the green “learn“ button (the only one) located on the bottom of the black alarm box, leftmost box of the brake pedal on the firewall. Then press the lock/unlock button on the remote(s). The Option button can be programmed to do the same thing by pressing it next if you wish.
    The remotes/alarm should NOT lose programming when changing batteries or if the car battery is swapped.
    ( From a post by Tone)
    Anita
    2000 Ebony #263
    AnitaProtich.com
    2001,BLACK,VX,0163
    Thanks Anita (& Tone)! I'll try it. Wondering how this happened in the first place!?!
    2001,BLACK,VX,0163
    One question though... does this also explain why the LED on the dash stays on constantly? I'll try resetting it later today....
    Sep 2004
    1999, Astral Silver, VX, 0938
    Try disconnecting the vehicles Battery for a few minutes first.
    2001,BLACK,VX,0163
    No luck. Tried resetting it & remotes still don't work & light on dash stays solid red....
    Any other ideas (or am I doing something wrong)??
    Thanks!
    LED light on dash will remain solid until you reset the device.
    Dealer should be able to do it for you. Takes all of 30 secs when done properly. I am sure this is "valet" mode.
    Max.
  1. Missing Security Box
    By VX MileHigh in forum VX Talk...
    Last Post: 10/09/2012, 07:14 AM
  2. is my vx security alarm faulty
    By djvx in forum VX Talk...
    Last Post: 12/08/2010, 07:35 PM
  3. security; Ravelco
    By cyronman in forum VX Talk...
    Last Post: 05/25/2007, 12:31 PM
  4. security light help
    By VCrossGurlie2006 in forum VX Troubleshooting...
    Last Post: 12/23/2003, 08:01 PM
  5. OEM Security Alarm
    By Jonnie in forum VX Talk...
    Last Post: 08/10/2003, 04:30 PM
