Results 1 to 15 of 17
Thread: Transmission Flush Question
    2000, Foxfire Red, 0619
    Bg
    Thats a good question. The shop that I took my VX into was insistent on using the BG family of products and that the flush was sufficient vs a fluid/filter change. I look forward to hearing what the board has to say!
    Mikey
    Aug 2003
    1999,Silver,Vehicross,0928
    i personally wouldnt feel like a flush is sufficient to a fluid/filter change. i mean the filter and the drain plug both catch alot of teh stuff floating around in there. if u dont change the filter, well then the stuff is still caught in teh filter.
    Nov 2002
    Arrow
    Unless they've got little faeries in the flush machine to remove particulates from the filter it's just a bogus claim. Kinda like extended-interval oil. Sure, the oil may be good for a ton of miles but where does all the contaminants go?
    '99 Ebony Black VX, 0339
    I STRONGLY recommend the flush as it is the only way to change the fluid in the converter. Then I would add one of the new tranny filters I found at SEMA to filter down to 15 microns - the pan gasket only filters rocks 60 microns and larger. Filter is $25 and simply mounts in the tranny cooler line. It's not on my website yet but I have them ready to ship.
    Nov 2002
    Arrow
    Tone, do you know if the 4L30E generates enough pressure to consistently flow through a 15 micron element? It'd be a good idea to upgrade the stock clamps and hose to avoid a line popping off or rupturing, just in case.
    Filter has a bypass built in so it only filters a portion of the fluid each time to allow proper flow. Standard screw clamps are all that is needed. I spent a good deal of time with their engineers @ SEMA as it seems like such a simple but effective solution. There are other filters out there but they don't incorporate a bypass valve and use inferior filter media. Good question!
    http://www.epntz-filter.com/sect2a.asp
    Aug 2005
    1998 red VX 1385
    Hi,
    Ive just had mine done, the full monty for $NZ375. There is a magnet in the JDM version that collects metal bits in the pan. I had about 5mm of metalic sludge on mine, something that my box can sure as hell do without.
    Go for the pan removal, new filter, and flush.
    Cheers.....
  1. Transmission Flush, panacea or poison?
    By Grif in forum VX Troubleshooting...
    Last Post: 11/24/2010, 04:19 PM
  2. Transmission Back Flush
    By Mark B in forum VX Talk...
    Last Post: 06/03/2008, 03:52 PM
  3. Transmission flush with new filter review
    By Syntek VX in forum VX Talk...
    Last Post: 10/07/2005, 08:09 PM
  4. Transmission Flush
    By Child's Play in forum VX Talk...
    Last Post: 01/09/2005, 03:33 PM
  5. Transmission Flush
    By wfjfg in forum VX Talk...
    Last Post: 11/09/2003, 09:29 PM
