Results 1 to 14 of 14
Thread: window problems -help!
    Feb 2005
    2000,black,VX,0206
    arial black3black
    I have a 90' Vehicross here in Ohio. Both my electric windows are messed-up.
    I am 3rd owner, so no warrenty(I guess). My independent repairshop quoted me today $500 each to fix. They said they have to get entire window, since
    the retainers(small plastic part that attaches to bottom of window) can only
    be ordered as part of the window assemply. Anyone know another (and
    less costly) alternative! $500 per window is way more than I want to spend.
    thanks.
    wicket1c jfrank90@hotmail.com
    Thanked: 7
    If you do a search on "tab" you will get a number of hits. THis thread might be of some use to you:
    http://www.vehicross.info/forums/sho...&highlight=tab
    Read up on Bulldoggie's posts as he talks about the broken tabs and his repair.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    May 2004
    No VX anymore. :(
    Do yourself a favor and glue them back together yourself. It'll take you a half day of easy work!
    Steve
    Feb 2005
    2000,black,VX,0206
    Not sure I follow you-I haven't seen the parts yet. Do you mean glue the Retainers
    back together?
    Thanked: 7
    At the bottom of the window is a plastic tab. When the tab breaks, the expensive solution is to purchase a window as Isuzu does not sell just the tabs. Several members of the site have glued the tabs back in place using various strong glues or epoxies. Fixing the tabs is not the only solution you should look into.. there are the causes that contribute to your problem. Nice thing is that several member's here have taken time and photographs helping to describe their fixes.
    May 2004
    No VX anymore. :(
    Here's a thread where I posted my window fix pics. My tabs weren't broken, though.
    http://www.vehicross.info/forums/sho...window+silicon
    Feb 2005
    2000,black,VX,0206
    Hi Anita,
    Thank you so much for responding. Q. I'm new to this Forum stuff -how do I get to
    "Bulldoggie"? info.
    Dec 2004
    '99 VX Astral Silver #0949
    search "window fix"
    study "Moncha's fix" and "Bart's fix" they work for most VX's. there is also a link to "window Lube" pictures that shows great step by step door panel removal instructions.
    Study my fix as it is for extream alignment fixes like yours.
    if you click on a users name it gives you the choice of viewing all their Gallery or posts.
    if you were closer I would give you a hand.
    I'm hopeing to make a manual to simplify info.
    GOOD LUCK!
    Feb 2005
    2000,black,VX,0206
    Hi Bulldoggie,
    Where do I find "Bart's fix"? I didn't see it in search. Has anyone made metal replacement clips?
    Dec 2004
    http://www.vehicross.info/forums/showthread.php?t=5845
    Sorry it's "Bert's fix"
    Joe Black's home page has more details and pictures of this fix.
    Mar 2007
    2000, YELLOW, VEHICROSS,0636
    there is a place in los angeles that have many car glass repair shops all in a 3 block radius. they use plastic tracks from other vehicle or made one up on the spot and it only cost 35 dollars. this people are quick they will take out your window and fix it in less than 1/2 hour. i still have to use my hand to help it guide up but that is ok.
    Jun 2007
    2001, Proton
    Yes there is a guy on here who has fashioned metal clips his info is Tim Parker goes under the name airtribe for his business his not sure right now how to contact he does post here though
    Quote Originally Posted by circmand
    Looks like this post was started in 05 ? But here is my info for the Metal window clips..........
    www.streetboutiquecustoms.com
    Tim
    Jun 2007
    2001, Proton
    Yeah I missed those old dates in the stream and was looking at current posts and just answered.
  1. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  2. Window Problems
    By SIRCO in forum VX Troubleshooting...
    Last Post: 10/20/2007, 12:26 AM
  3. Power Window Problems
    By zeebob1 in forum VX Troubleshooting...
    Last Post: 07/25/2007, 10:48 AM
  4. Driver Window Problems & ISUZU Dealers
    By BeeVenom in forum VX Troubleshooting...
    Last Post: 10/02/2004, 08:34 AM
  5. Window problems!!!!!
    By sam in forum Meets...
    Last Post: 03/13/2004, 05:12 AM
