Hi guys,
A little of your all-knowingness would be appreciated!
Here goes. When I let off the gas, I hear a humming/whirring/groaning sound like the tranny/TOD is engaged(?) while coasting. Is this normal? The engine RPMs decrease as they normally would when you let off the gas. It doesn't sound like its about to fall apart, but I certainly want to know if its abnormal and needs to be looked at. I've only had the VX for about 6K and I don't recall hearing it when I first bought it. I know the VX has a complex transmission/TOD system and I acknowledge that it could be completely normal.
Have/Do any of you experienced this? Any help?
Thanks,
Mikey
00 Foxfire 30K
i dont want to sound cynical but good luck getting it resolved!! I've had the same problem for over a year, its been into the dealership over 15 times under warranty, they've rebuilt the rear diff 3 times replaced the front and rear diffs, transfer case, front drive shafts and a hundred other things. The noise is still there, everyone agrees it shouldnt be but no one can fix it. Isuzu are flying out a manager and their best service tech next week to test drive it and try and figure it out.
