I have it on pdf now and still can't attach it to the post. What gives?
Here's a caption for the file if I can ever upload it.
"If there's a blank, it was not important enough to fill in. I chose not to mess with the ABS leads after I determined that it had no effect on the TOD. I'm sure that the TOD uses the ABS as an input, but the 4WD Out to the ABS is unreadable.
TPS signal is variable via potentiometer at the throttle. Roughly 0-13V.
The VSSs are weird Hall-effect sensors operating at 4-5V.
The indicators work as explained in the maintenance CD. Switched grounds indicate an "on" state."
