I have a few questions and was wondering if anyone could help with them:
1. I was wondering what the best place is to buy the serpentine belt. I got the serpentine belt from Napa for $40 which seems a bit steep. Checked pepboys and their price was higher. I don't want to get the Goodyear Gator since it is louder at high rpms.
2. Also, i've checked around and found the best deal on synthetic Mobil 1 ATF to be $6.19/quart and Mobil 1 geal oil to be $8.19/quart at Autozone. Does this sound like a good price or can i buy the fluids cheaper.
3. I've read that a good pump to use while changing the fluids is the valvoline pump that works with the drill. I was wondering where i could find one of these.
4. I know that the transfer case and differential fluids are simple drain and fill. However, since i've never done this, i wanted to know if there is a guide for this (to point me to the drain and fill locations). Any pictures would be even better.
5. After changing the fluids, is there anything special that needs to be done to make sure the drain location is sealed and not leaking. Is there any sealant or anything else that needs to be used.
Thanks.
