Results 1 to 7 of 7
Thread: need help with wierd clunk noise
    thanks guys, but im pretty sure its the door and not the box moving. if i take off the back plastic cover, the box fits fine and it doesnt make the noise, but with it on it does b/c its pushing the door out. i searched and found the thread about adjusting the latch. So when i get back ill give it a try, but ill also try the others just to be sure. Thanks guys
    1999, White, Ironman
    What you are hearing is most likely the plastic on the door flexing and popping back out. I had that problem with my old box before I went with the kicker L5 that took up less space. The sound echos through the spare tire space and sounds like one heck of a clunk. I thought my rear end was going at first because when ever I would accelerate or go over a bump the box put pressure on the plasic it would make the noise. You can try putting some bracing between the spare and the plastic to make it more ridged, but the best solution would be to build a box sized for your VX that doesn't rub. Hope this helps.
    So what did you call that thing again?
  1. Tod acting wierd
    Last Post: 02/14/2017, 12:24 PM
  2. wierd problem
    By spitfire5454 in forum VX Troubleshooting...
    Last Post: 11/28/2008, 09:43 AM
  3. wierd things in your vx
    Last Post: 01/11/2007, 04:28 PM
  4. Clunk and Noise
    By ThunderChicken in forum VX Troubleshooting...
    Last Post: 07/28/2004, 08:38 PM
  5. Wierd noise after 75 mph?? Help!!
    By melonque in forum VX Troubleshooting...
    Last Post: 02/11/2004, 05:57 PM
