Results 16 to 30 of 35
Thread: They are comin to take Tone away.....
  1. #16
    The 3-valve per cylinder thing makes me say ML as well.
    That model needs to jump into the MB and drive it to a JackInTheBox to get some food. She looks hungry.
  2. #17
    Driveline
    1
  3. #18
    Imagine riding on that.....
  4. #19
    1999, Ebony Black, VX ,1976
    here are some more specs. that was way to easy. shawn
    engine
    type. .
    90 degree V-8, die cast alloy block, alloy heads.
    displacement. .
    5.5 L
    bore. .
    3.82
    stroke. .
    3.62
    compression ratio. .
    10.5:1
    output. .
    342 hp @ 5,550 rpm
    torque. .
    376 lb-ft @ 2,800 - 4,500 rpm
    valve gear. .
    Belt-driven SOHC, 3 valves per cylinder.
    redline. .
    6,000 rpm
    drivetrain
    type. .
    5-speed automatic with Touch Shift.
    final drive ratio. .
    3.46
    1st gear. .
    3.59
    2nd gear. .
    2.19
    3rd gear. .
    1.41
    4th gear. .
    1.00
    5th gear. .
    0.83
    reverse gear. .
    3.16
    performance
    acceleration1 . .
    0-60 mph in 6.4 seconds.
    top speed. .
    155 mph (Limited).
    towing capacity. .
    5,000 lb.
    suspension
    front. .
    Double wishbone with lightweight, high strength, forged aluminum-alloy upper control arms, and lower double wishbones forged from high strength steel. Torsion bar springs, stabilizer bar, gas-pressurized shock absorbers. Up to 8 inches of wheel travel.
    rear. .
    Double wishbone with lightweight, high strength, forged aluminum-alloy control arms. Coil springs, stabilizer bar, gas pressurized shock absorbers. Up to 8 inches of wheel travel.
    brakes
    front & rear. .
    Dual-circuit power-assisted 13.58 inch ventilated front discs/13.5 inch solid rear discs with 4-piston front calipers.
    steering
    type. .
    Rack-and-pinion with speed sensitive power assist and integral hydraulic damper.
    turns lock-to-lock. .
    3.62
    turning circle curb-to-curb.
    39.0 ft.
    wheels and tires
    wheel size(front). .
    9x18 in
    wheel size(rear). .
    9x18 in
    wheel type. .
    Aluminum Alloy
    tires. .
    285/50 R18 front, 285/50 R18 rear
    1COOLVX
  5. #20
    2000, foxfire red, 0474
    Wink
    I found it!!!
    This is a pic of the new car:
    http://www.big-boys.com/pictures/picture1786.html
  6. #21
    Feb 2003
    2001, Black, VX, 0781
    Quote Originally Posted by Triathlete
    Shes nice...
    She's definitely had a few aftermarket upgrades, probably bolt-on.
  7. #22
    Sep 2005
    99, ebony,VX
    Talking tones legacy
    In answer to your question Mr. Wayne;
    Yes it comes in black!!
    99 ebony #0336 in LA
    details to follow
    thanks tone!
  8. #23
    Here she is...
  9. #24
    Nov 2002
    You gave up the VX for a car?
    I'm... shocked.
    Okay, okay... you're kidding? Right? C'mon, show us what it really is...
    We're waiting... Impatiently, I might add.
  10. #25
    Jun 2003
    1999 Victory Ironman 1703
    Quote Originally Posted by Tone
    Here she is...
    What dribble about your mistake...ha!
  11. #26
    It'll be in Moab with Swampers on it, will ya'll? Those tire on there are 31x12" with an aggressive street tread, they don't seem to make offroad tires rated for 155MPH! This ain't no car - there's a stout tranfer case, 9+ inches of clearance and plenty of power - crank the tbars and it's all set to go.
  12. #27
    Nov 2002
    Not a car? Unitized body = station wagon.
    Moab? Not for a while yet, Uwharrie is about as far as I want to go until the support rig is sorted out. Getting an eye for Tellico too.
  13. #28
    Aw, cmon Tone. That aint you. Wider tires, large rotors, panted calipers.... big deal.... I still see those all over around here..... with soccerball decals on the tailgate.
    Now, if you had of gone G Class, with that AMG goodness.... then you would be talking. I am currently looking at a silver one here. Discontinued, so I think I am gonna haggle a bit. Kinda reminds me of the purchase power with the VX.
    Nov 2002
    Gelandewagens RULE! Not too mention they could pass for the twin of a 1st-Gen Trooper. Except they've got a soft-top SWB model and turbo-diesels galore here in the US.
    Hopefully Tone's next shocker isn't going to be about a "special" operation he's been saving for!
  15. #30
    Jul 2002
    99 Ironman
    Hey Tone,
    Welcome to the Mercedes family. I've been waiting for a crossover friend. I sure do miss my VX though. Still haven't found out who bought it and if it has a good home. Mercedes assured me that it would be fine when I traded her , but I think they just wanted my 50 Grand... lolololll..
  1. Tone this is for you
    By Todd Adams in forum VX Talk...
    Last Post: 02/29/2008, 06:16 AM
  2. Thank you Tone
    Last Post: 06/24/2005, 06:19 PM
  3. Tone! HID Kit?
    By marximus in forum VX Talk...
    Last Post: 12/31/2004, 01:30 AM
  4. Got a PV !!:-)Thanks Tone
    By 02RodeoS in forum VX Talk...
    Last Post: 12/12/2003, 09:54 AM
  5. TONE! Please come in!
    By coachreed in forum VX Modifications...
    Last Post: 07/03/2003, 03:01 PM
