When I get on the gas and have the shifter in anything other than D. , I let off the gas using the decel from the engine to slow me down and it kicked out of 4 hi into a neutral position. It only happens when I am at high rpm and slow down. So i had to pull over, put the gear selector in N, pull the emergency brake and put the 4WD back in high. Any ideas why this would happen???
