Results 1 to 15 of 16
Thread: Small round lights, what bulb?
    2001, Yellow, Vehicross, 0786
    I have one of the small round lights out that are mounted in the front bumper, i remember once reading you can replace them with i think a 50w halogen or something, anyone remember what bulb it is?
    Thanks guys
    Pete
    Previous owner of #1068
    One of mine just burned out too... so I finally took the advice of many from here and put in the 18W Malibu bulbs from Home Depot. They look great, and were $5 for a 4-pack.
    does anyone know if there is any better upgrades for those that will fit in the stock spot and mount without much trouble? i want some lights that will actually give off some light. thanks for the help.
    pbkid
    99' Astral Silver
    Quote Originally Posted by pbkid
    pbkid
    Not really last I checked, at least without melting the housing
    Best bet is to swap out the stock lights with a 3 inch or so diameter fog/driving light. That's about the only way to get some real light from that area. Try a search for fog lights and you'll find many posts on what other members have done and even several How To's on replacements.
    Live Free or DIE!
    Feb 2003
    2001, Dragon Green, 1023
    I just put in the PIAA W2 18W HID replica lights that people suggested in the forums..... They were $18 on line including shipping from Audi.. .Took 10 minutes total to install. 5 minutes your second time.. They are super bright, but now I need to get new headlight bulbs, because they don't match..
    "If you're not living on the edge, You're taking up too much space...." -Perry Kloska
    May 2002
    2000, Proton Yellow, VX, 0584
    There's always a complete change out like I did..
    http://www.vehicross.info/modules.ph...ewarticle&id=2
    There are several others that changed out the lights too.
    Scott / moncha.com
    So i ordered and installed the PIAA 18w wedge bulbs...Awesome!!! If you havent allready done so its one of the best $15 mods for the VX Nice cool blue much brighter light than the origionals.
    But be warned!! you'll like 'em so much you will have the replace the headlight H4 bulbs to match, about $70 if you go with the PIAA's again but well worth it, much brighter and cooler lights, updated the car, got lots of positive comments too.
    Pete
    Sep 2003
    1999 Astrial Silver VX
    Are these the same ones you're talking about?
    http://www.a4stuff.com/Merchant2/mer...ode=PIAA-19224
    yep, but then you need the H4 headlight bulbs to match
    '99 Blk 0089
    I changed mine out to a set of 55W small Pilot driving lights. And NO, nothing melted, just need to change out the headlight fuse under the hood from 10A to 15A since it pulls a little more current. I can't find the thread but do a search and it has detailed instructions. Got the Pilot light at Autozone for like $20 and a couple of 4" rubber hose coupling thingy & hose clamps from Lowes for $10 (I think). Whole project costed me $30 and a few hours.
    1999, ASTRAL
    Exclamation The OEM bulb is only 3.5 Watts...
    Quote Originally Posted by PeteVX
    Thanks guys
    Pete
    The OEM round aux light bulbs are a mere 3.5 watts. You can upgrade them with 4 watt Malibu bulbs from Home Depot and get a somewhat brighter OEM glow. Higher wattage bulbs are available in 7, 11, and 18 watts, but I am not certain what long term impact that would have on the circuit designed for 3.5 watts. Others have gone as high as 18 watts and reported no problems. Just know that going from 3.5 watts to 7 watts is a 100% increase in power on that circuit, so proceed with caution.
    NAVIGATOR
    7watt bulbs are NOT a problem in the round light and you could probably go as high as 15w if those are avail. Lots of air space and distance in there.
    Had 'em in for 2 weeks now and they have been great. Like you said, a tad bit on the blue side and the PoPo here loves to lay the smackdown on that, but its such a light blue/white that you have to look at them for a good long while to really sense any blue at all. Its not blue enough that it bothers me, so I will live.
  1. Where's fuse for front round parking lights?
    By VX KAT in forum VX Troubleshooting...
    Last Post: 10/01/2013, 06:31 PM
  2. How to change small circular lights in the front bumper bumper
    By Fiddlecrusher in forum VX Troubleshooting...
    Last Post: 01/20/2010, 02:17 PM
  3. Round park-n/drive-n lights
    By XCross69 in forum VX Talk...
    Last Post: 01/21/2007, 10:09 PM
  4. How do I unscrew the round parking light to replace bulb??
    By zacflash in forum VX Troubleshooting...
    Last Post: 02/12/2004, 02:31 PM
  5. Replies: 13
    Last Post: 04/28/2003, 03:57 PM
