Results 16 to 30 of 34
Thread: gas guzzler
  1. #16
    May 2004
    No VX anymore. :(
    My gas gauge goes down 1/2 way after burning about 3 gallons.
    I get 12-13 miles per gallon in the city with A/C on.
    Steve
  2. #17
    '99 Blk 0089
    I have a 2" lift with 33" tires and get about 11mpg city, 15mpg hwy.
  3. #18
    Transio,
    Mine's kinda strange too...usually under all city conditions (I know, I'd have to drive 4 hrs. to get to an actual city) mine will go dwn. to the 3/4 mark at about 45-50 miles.
  4. #19
    Julian, how on earth did you fit 33s with just a 2 inch lift? You must have done some serious fenderwell mods!
  5. #20
    Aug 2003
    1999,Silver,Vehicross,0928
    Is that 1/2 tank because the gas gauge said it was?...or 1/2 tank because you filled gas, drove across town & back, then refilled @ 11 gal. +or-.
    I'm a little suspicious of your gas gauge.
    Just a thought...
    Ldub
    im with this man my gauge is stupid too...it drops a 1/4 tank in 2miles. i get around 17~ mpg combined on a stock 56k mile vx.
  6. #21
    Jun 2005
    2001 Dragon Green Mica ,#1393
    kinda the same.. i figure im getting around 200 miles a tank.. or mostly about 10 mpg... all city driving though so i am not sure if this is normal... even though it is seeming more and more like it is.
    If Life is passing you by... DOWNSHIFT!!!!!!!!
  7. #22
    Sep 2005
    1999, white ironman, 1947
    well I cleaned my fuel injectors last night and it helped a little but i took it in this mornin to the isuzu store and they looked at it for about an hour or so. It turns out that I wasnt really burning a half a tank, the gas gauge sensor was screwed up. Apparently it was sticking on something. So the guys at isuzu ordered me a new one.
  8. #23
    Apr 2003
    2001, Ebony, 0761
    Mpg
    I've been getting 13 to 14.4 mpg city, 17 to 19 mpg highway. Stock engine & exaust.
  9. #24
    Apr 2003
    ex IronMan
    You will like to hear THIS. When I am towing the boat I am averaging 14-14.5 miles to a gal on a highway.
    Now I use VX only to tow and maybe weekend stroll because of gas prices. The rumor is it is going up on Saturday again......
    Andrey
  10. #25
    99' Astral Silver
    Quote Originally Posted by Mr.Quackers
    There's something wrong with that.
    Obviously, a lot of factors come in to play with gas milage but I'm getting at least 300 miles per tank before the light comes on. When I fill up, I still have a little over two gallons left. Considering we have a 22.5 gallon tank, 300 miles for 20 gallons seems to be pretty good for the VX
    Live Free or DIE!
  11. #26
    ex 1999 ebony black vx 1979
    I commute in rush hour traffic (25 miles in hour to hour and half) twice a day and I still get at least 300 miles to a tank. I usually fill up at around 310 miles and I've never had the fuel light come on. Generally takes just shy of 20 gals to fill. I've found that if I use super instead of regular it not only runs better, but I get a mile to mile and half more per gallon. Maybe Washington gas is better?
  12. #27
    If that rate of usage was ever true, you would be smelling gas.
    I have had two gas leaks from cracked hoses (Supply and return) under the EGR valve at 44k mi.I have also had the jumping gas meter condition so popular with the VX. There was a time in 2003-2004 when the oil refiners left alot of sulfur in the gas which formed H2SO4 and ate a little of the sender wires. This made the national news. I do not think anyone got a refund. This was said to be localized in the south, but mine failed at just that time. Since the oil companies are making so little now, we should not be suprised that they cheat a little in processing. Greed knows no bounds (If you have no recourse-of course.).
    Roy
  13. #28
    Jun 2005
    Quote Originally Posted by VehiX
    so something must be wrong then. any idea how i can fix this? or at least how i can help it out?
  14. #29
    '01 Ironman
    Are you lifted Mr Quakers? running larger tires? what mods have you done if any?
  15. #30
    Jun 2005
    I got the vx not but maybe 3 months ago. so as far as mods i have not done any yet other than professionally installing the Pv muffler. i got it with P255/70 r16 yoko tires on 15" eagle alloy rims. (not really sure what that means but i got it off the tire) as far as a lift goes, neither previous owners have told me that they have lifted it so as far as i know, it is not lifted. (anyways of quickly checking?) the only other thing that i could possibly think of if it does have a roof rack on it. it has been taken care of very well and has not missed any scheduled maint. so.. maybe something might be wrong with the engine?
