Results 1 to 6 of 6
Thread: Exhaust flange (weld) problems
    '01 Ironman
    Well I just took out the passenger side exhaust last night, what a PITA had to drop torsion bar do not attempt yourself if your not an alignment wise person.
    Well I found the same problem that happened with my driver side exhaust before, the weld on the flange on the drop pipe just after the manifold has busted. I am curious if anyone elses welds broke there?
    Isuzu wanted $1000+ for the pipe (includes cats I guess) so I am just welding them back up. Is this a supercharged problem, or are others having problems, or is it just some lame guy at Isuzu that welded mine together? Does 5psi really make that much of a difference in exhaust pressure?
    Just seeing if anyone else has had the same problem.........
    I'm running 5 psi in mine without any problem.
    Scott
    '99 SC Ebony #1961
    no problems here.
    '01 Ironman
    btt
    You shouldn't be seeing an increase in "exhaust pressure," supercharged or not.
    It sounds like your exhaust is bouncing around, fracturing the weld where your tubing meets the most rigid part (exhaust manifold).
    I'd look for missing/broken exhaust hangers, then check for alignment issues that were incurred during installation of your PV muffler.
    If all elese fails, remove the entire system and bolt it back on in once piece, from front to back.
    A flex pipe or two may solve your troubles if that (reinstall) doesn't work.
    I've had the passenger side fail twice (replacement pipe did the same thing) - took them off and had them welded properly and no trouble since. I also had the driver side done once. They are more prone to break after adding a muffler as many shops do not support them right and it puts a lot of stress on that part (the factory weld is shoddy though).
    Supercharger at 20psi would not have any effect on this unless motor mounts are bad and the motor is twisting substantially under hard acceleration.
  1. Exhaust flange gasket
    By jmayer40 in forum VX Troubleshooting...
    Last Post: 01/17/2013, 06:03 PM
  2. Exhaust
    Last Post: 04/29/2010, 07:33 PM
  3. emission warranty ?? exhaust flange on converter
    By Dean68 in forum VX Troubleshooting...
    Last Post: 07/02/2009, 09:31 AM
  4. Learning to weld, or my new brush guard.
    By MustangO4 in forum VX Modifications...
    Last Post: 02/23/2007, 10:52 AM
  5. Exhaust problems
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 11/08/2006, 01:30 PM
