Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Jet performance reflash info
  1. #16
    2001, Dragon Green, 1342
    Quote Originally Posted by H3_VX View Post
    yes
    with the scan guage does it fix the odo
    Fix, no. It just gives you a corrected readout as to the speed your actually doing plus many other parameters, i.e,; water temp, rpm, MAP, Load, MPG, things like that plus engine fault codes and reset.
  2. #17
    Aug 2008
    Only thing I want to be able to do is recalibrate for tire size.
    With my oversize tires, I just use a more "analog" method-- the Discount Tire website "Tire Calculator". It will show your projected travel speed at various MPH settings.
    http://www.discounttire.com/dtcs/infoTireMath.dos
    For example, my oversize tires (275/65R18) run about 5 MPH above my actual speedometer reading. So if the posted speed limit sign says 60 MPH, then I just put my speedometer needle on 55 MPH with no worries.
  3. #18
    Arrow
    Uhhhhhh...
    Math don't work that way Riff...
    It's all about the %.
    example: a .07% difference in tire size = these speedometer values...
    55 = .07x55=3.85, so 55=58.85
    60 = .07x60=4.20, so 60=64.2
    65 = .07x65=4.55, so 65=69.55
    and so on...
  4. #19
    2001, Ebony Black, 1153
    Haha, well I had to disassemble my gauges and needles to install intelli-glow needles, so last time I had the needles off, I had someone with a stock car drive 65mph next to me with cruise on and I matched their speed with cruise on and then I replaced the needle at 65 mph and then I had them speed up to 70 and then down to 60 and stayed with them and checked to make sure my speedo was close and done.
    I know it is not a perfect fix, but it is nice to know that at around 60-70 mph the speedo reads true :-)
  1. Reflash PCM
    By AnalogVX in forum VX Troubleshooting...
    Last Post: 05/31/2015, 09:35 AM
  2. Is it possible to retune or reflash..
    By nzgreenfox in forum VX Modifications...
    Last Post: 05/30/2014, 01:33 AM
  3. Mud performance art
    Last Post: 02/03/2009, 10:22 PM
  4. performance mods
    By byrona64 in forum JDM Parts & Accessories
    Last Post: 09/02/2006, 11:17 AM
  5. Poor performance
    By SIRCO in forum VX Troubleshooting...
    Last Post: 11/16/2005, 10:51 AM
