Results 1 to 7 of 7
Thread: 15" wheels
    15" wheels
    Hi, new to the forum! Just looking to buy a vehicross and have a question.
    I am looking at 15" wheels for the vehicross. Will they fit? I want to run 31x12.50 pro comp x-terrains that i already own.
    No need to lift?
    May 2004
    No VX anymore. :(
    Whether the wheels will fit depends on the bolt pattern, width, and offset. The diameter will determine if they can fit the brake disks, but I don't think that'll be a problem. Bolt pattern has to be 6 x 5.5" and backspacing = (width - offset) / 2 should be about 4 to 6". You will have to lift and probably trim some cladding with those tires.
    Steve
    You'll also want to check the size of the center bore. The VX has a larger hub diameter than most .
    '01 Ironman
    That setup will work without a lift, you will just have to trim a little bit of the front cladding. Try to find a good offset too. The 12.5 is what is going to make the fit difficult without a lift.
    Nov 2002
    Arrow
    All good info above, especially the center bore. I've got a set of 15" wheels from a Nissan Frontier that are currently shod with Yokohama 30X9.50 Geolandar MT+ tires. The only issue I had was clearance of the upper A-arm, which removed about 1mm of material from the inner portion of the rim. Caliper clearance is tight, so just be sure to test fit before you commit. Nissan truck wheels are a good choice though, as there is a variety of styles and you can find them in quantity at just about any used wheel shop. I got mine from eBay as a "removed-new" set complete with center caps and hardware for less than $200 delivered.
    As i am in the middle east fitting after market wheels is difficult. I will check what factory styles the dealers have in stock. I am also looking at the calmini 3" lift. What is the biggest tire you can fit with the 3" lift without rubbing? I do not want to re-gear as well.
    I could keep the stock 18s. Just need to find a nice offroad tire. I guess nitto makes some.
    Thanks for the info guys.
    '01 Ironman
    If you were to put the 3" lift on you would be able to fit 32x11.5 tires easily maybe just some minor trimming of plastic up front. 33x12.5's are a bit big and require trimming around the back of front cladding. (And I am still getting rubbing in some situations)
  1. 22" Wheels
    By chasemcgrady in forum VX Troubleshooting...
    Last Post: 02/28/2013, 11:32 AM
  2. Stock 18" to 15" Wheels
    By Stevil6531 in forum Wheels and Tires
    Last Post: 11/28/2012, 01:20 AM
  3. some new 20" wheels
    Last Post: 01/12/2012, 11:33 AM
  4. ? about new 18" wheels
    By VX Grrrl in forum VX Talk...
    Last Post: 12/30/2004, 08:04 PM
  5. Anyone with 20" wheels
    By Bagheera in forum VX Troubleshooting...
    Last Post: 04/27/2004, 01:54 AM
