Results 1 to 15 of 16
Thread: Big lifting for the VX
    Jun 2005
    2000, Black
    Is there any option to lift the VX higher than 3"? I am getting ready to buy one and all I have found is this kit from DOR products. Also, is this all I would need if I decided to go with this one or is there anything else I would need to get/do to make it work? Please help!!
    -Josh-
    Use the search...there is plenty of info posted on this board about lifts. In a nut shell unless you op for the custom fab route (SAS) you are stuck with 3 inches. Two ways are the OME prings or the Calmini set up. The CVs can't handle much more than 3 inches of lift and the axles can't handle much more than 33 inch tires if you use it off road.
    2001,Yellow,0763
    OME 912's and a 3" body lift will get you ~ 6". The body lift isn't hard at all except when it comes to the rear bumper.
    NC 1999, ironman, 0358
    What is involved in the body lift? I imagine that you disconnect the body from the frame and insert spacers of some sort. Is that it in a nutshell?
    Western North Carolina...
    Veni, Vidi, Velcro
    Where do you get the body lift from?
    I think the hard part about the rear is you have to refab mounts for your rear bumper or something?
    '99 Vehicross - Daily Driver
    '93 Wrangler - Tank in Progress
    2001,Yellow,0763
    Independent 4X is where I got my lift from. Best to call and ask for Matt. It's actually a Trooper kit so with a little common sense you will figure out which parts can be drilled/welded to work on a VX. I will be posting some pictures of what I did to mine this weekend for another member. What I did was cut off the last cross member on the rear of the frame and re-welded it to the top of the frame rails just under the body.
    http://www.independent4x.com/
  1. Simple Lifting
    By Vaso in forum VX Talk...
    Last Post: 10/03/2014, 10:31 AM
  2. Lifting the VX
    Last Post: 02/23/2008, 05:33 AM
  3. Lifting
    By Nerve_Gas in forum VX Modifications...
    Last Post: 06/30/2006, 06:38 PM
  4. Lifting the VX
    By dtruax in forum General Tips...
    Last Post: 01/11/2006, 08:37 PM
  5. Lifting the VX
    By NC_VX in forum VX Talk...
    Last Post: 06/24/2003, 03:47 PM
